I TRIED!! (
but failed..) using my normal techniques, but decided to show what/how I attempted it, that
may benefit others!
'Google' has a little used/understood feature, where you can search 'Images', as well as for 'text'.
If you go to...
https://www.google.com.au/imghp?hl=en&tab=wi&ogbl or look at the Google Window after 'Images' after
you search for some Text, you will see a '
Camera' Icon at the right-hand end of the search-bar. Clicking on that Icon, and
then selecting "
Upload an Image", you can select an image/photo that you have, and it searches the Internet for something
similar, and shows the results! It is NOT perfect by any means, but often helps you. So what I tried was this...
I downloaded
your 'Photo', and edited it to just contain the '
Logo' we are interested in. As in this .jpg file...
Now I used some Vector Conversion software, to create a smooth result, and saved it as a .png file...
I then used BOTH of these, (
without success this time!), using the above 'method' for image-search. Seems too obscure!!
Then I assumed the letters were 'DD' and performed a search for... '
DD icon'. Found hundreds of results, but not yours!
I wondered if it was supposed to be 'OD' and searched for... 'OD icon'. Same result.
I even tried just 'D' in case the 'black' part was just meant to be a Shadow!! Nope...
I hate things like this beating me, but maybe this can help others trying something similar !!!
