Thats the fix I would instinctively try for, passive safety is almost always better then active systems.
Apart from anything else some poorly trained operator is less likely to override a passive safety system (Poured concrete also trumps bolted on metal here if you can manage it).
See the accident at Alton towers in the UK where a rollercoaster had multiple cars in movement at the same time (Well it increases numbers of riders per hour) with railway style block interlocking for safety. While fixing an issue someone overrode the interlocking with a stopped car part way around the track).
The automation know there was a problem and was holding the next car waiting for the block ahead to clear, but the maintenance "Engineer" (Who had not read the O&M manual, and had not actually been out to eyeball the blocked section) 'knew' better.
Result of the coming together, several teenagers with leg amputations and a £5M fine for the operating company plus civil settlements to come.
The sort of thing that any engineer is both shaking their head at and quietly thinking "There but for the grace... go I".
Regards, Dan.
