Author Topic: [Solved] Driver Assistance: ISA NIC software for DOS  (Read 3341 times)
Offline Halcyon
« on: June 13, 2015, 02:30:01 am »
Apologies for the "IT Support" thread however I'm a bit stuck. After days of searching, I'm still unable to find DOS packet drivers for either of these two network cards:
- Macromate MN-200CT (based on the AT/LANTIC II chipset; Made by Texas Instruments?)
- SMC 83C795QF (this came with a driver disk but only included drivers for SCO, Windows NT and later)
I basically just want to give an old machine of mine basic file sharing capability through MS-DOS as I have done with another 'vintage' computer I have.
From memory I think one of them might have worked with generic NE2000 drivers but I can't find any of those either.
« Last Edit: June 13, 2015, 08:51:18 am by Halcyon »
Offline ranch varment
  • Banned!
Re: Driver Assistance: ISA NIC software for DOS
« Reply #1 on: June 13, 2015, 02:48:05 am »
i wonder if you could code it with c and its not that hard,  because they might be generic. (especially ipx)
Offline Halcyon
« Reply #2 on: June 13, 2015, 02:50:58 am »
That last time I programmed anything was using LOGO as a child and Visual Basic and HTML in high school :-)
(I'm more of a hardware/enterprise networking kind of guy.)
  • Banned!
« Reply #3 on: June 13, 2015, 03:15:34 am »
see if doom will recognize it?  or norton commander, but i can only remember doing twin serial com connection with that, im not sure if it had a more proper protocol.
« Last Edit: June 13, 2015, 03:18:55 am by ranch varment »
Offline John Coloccia
« Reply #4 on: June 13, 2015, 03:27:47 am »
Don't know anything about these guys.  If you get some weird old school virus, like Joshi, or your computer explodes when you try to download it, or your coffee tastes different in the morning, or whatever, don't blame me.  :)
...but they do seem to have an ne2000 driver for DOS.
http://www.network-drivers.com/companies/715.htm
Offline Halcyon
« Reply #5 on: June 13, 2015, 04:16:58 am »
Yeh those sorts of websites (including network-drivers.com) force you to download crapware before you can actually get the driver (if in fact they have it at all). Unless it's in a ZIP file, I'll pass :-)
Offline helius
« Reply #6 on: June 13, 2015, 06:21:30 am »
The keywords you want to search for are "packet driver", ODI, freeDOS, freeTCP, NLM, NDIS, and crynwr.
The "AT/LANTIC II" looks to be a member of the DP83* series of controllers from National Semi. One of them was used on the ever-present Novell NE2000.
The second card is a SMC 8416T. A packet driver was made by Crynwr, I've attached it here.
Offline Halcyon
« Reply #7 on: June 13, 2015, 08:09:18 am »
Success!
It turns out those AT/LANTIC chipsets are actually NE2000 compatible and that the Microsoft Network Client 3.0 for MS-DOS has the proper drivers for it (including TCP/IP protocol support).
It was actually very painless to install, just a matter of running the setup program although it does use a bit more memory than the ODI drivers.
« Last Edit: June 13, 2015, 08:13:22 am by Halcyon »
