The SCPI command ":MEAS:PDEL? CHAN1" only works if I do a manual UI Measure -> Delay1->2^ first. After that works like a charm.
When it does not work it outputs a dummy 9.9e+37 value...
At least with the first crap example (100Hz or 1KHz sinus wave on RC filter) tested.
Useless. What's the point?
Regarding SCPI this throws me to downloading the waveform, fiddling with the points, deal with the noise crap...
I suppose the 00.04.04 firmware from 2020 does not address these issues...
