Author Topic: DSN-VC288 panel V/A meters - frozen after zeroing.  (Read 1018 times)
Offline CaaarloTopic starter
  • Country: ar
« on: December 25, 2021, 11:15:36 pm »
I have just put my hands on these meters after having them resting on a shelf for 3 or 4 years.
The worked ok, but wanted to calibrate zero by using the popular procedure:
1-power off
2-connect a jumper between zeroing pads
3-power on
4-after some seconds, remove jumper.
Well, I did it on one meter, and got some weird result, so I thought it might be a defective unit. Then I tried the same procedure on another unit.. SAME THING !!!  :-//
After removing the jumper, the display won't return to normal operation, but will remain frozen showing -60V and --0A, no matter what input is present. Already tried zeroing again but nothing happens. The meters are basically bricked. Any solution besides firmware update ? I don't have a programmer for these MCUs.
