From what device was it recovered?
I see a lot of wires, does this module have a serial port? Some of them have a small 3 pin header on the board for serial. I think it even breaks out to the parallel header
Wow, looks impressive! Never seen a 4x20 characters of a 7x5 VFD matrix dots before. From what device was it recovered?
I'm thinking payphone. The last generation ones with the texting feature.
I've seen current generation industrial kit with these displays fitted. So not surprising they're in production still.More lifespan/thermally rugged than OLED, wider temperature range (OLED really does not like hot ambient if you drive it bright, VFD doesn't care), they're fairly rugged to physical abuse, and they don't go blurry and slow in subzero temperatures.But on the other hand high power consumption (makes it difficult for portable devices) and a relatively large form factor make them impractical in other ways.Fun fact, Noritake make VFDs and fine chinaware for your grandma. An interesting combination of abilities.
I bought a pack of thin (maybe 0.8 to 1 mm) plastic sheets on Amazon, various colors. I think they called them acrylic but they were more flexible like polycarbonate. Used some for contrast filters on CRT oscilloscope, as well as VFD displays. My favorite color is "rose", kind of pale pink. It makes the VFD look white, by filtering out some blue and green. Can be combined with smoke for additional contrast. I've also used colored "gel" or cello or cellophane sheets, which are very thin. This needs to go in between the VFD glass and some other durable lens like acrylic.
