Author Topic: Dust free lab !  (Read 3773 times)
Offline maxpayneTopic starter
Dust free lab !
« on: July 30, 2018, 08:36:17 am »
I am just tired of cleaning dust build up in my lab. Every 10 or 15 days I have to clean and it takes around quarter of a day to clean everything. My lab is in an apartment 4th floor.
I was wondering if you are facing the same problem and how you are tacking the problem.
or any idea to make your lab dust free.
Online Zucca
  • EE meid in Itali
Re: Dust free lab !
« Reply #1 on: July 30, 2018, 08:43:22 am »
My wife helps.
Can't love what you don't
Re: Dust free lab !
« Reply #2 on: July 30, 2018, 08:44:39 am »
Wish my wife would help !  :(
The following users thanked this post: PTR_1275
Offline Messtechniker
Re: Dust free lab !
« Reply #3 on: July 30, 2018, 09:04:02 am »
Try to identify the source of the dust.
Carpets? Aircon? Leaky window seals?
Dog? Cat? or any other hairy fellows?
Leaky door seals? One of the worst dust
sources is the bedroom. Keep that door
closed at all times. Fabric of chairs and sofas?
Just to give you an idea.
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
Re: Dust free lab !
« Reply #4 on: July 30, 2018, 09:12:48 am »
To keep something dust free you need to do four things:
1. Seal it.
2. Clean it.
3. Keep a positive filtered air flow through.
4. Clean yourself and anything that goes into it.
Basically just give up and clean it once a month.
The following users thanked this post: maxpayne
Offline nfmax
Re: Dust free lab !
« Reply #5 on: July 30, 2018, 09:21:01 am »
One tip: I find that a paperhanging brush is the ideal tool for dusting fiddly areas like control panels, bookshelves, drawer cabinets, etc. Long, soft bristles and no long handle to get in the way. Also useful for sweep up solder splats, wire ends & general bench crap.
« Last Edit: July 30, 2018, 09:51:35 am by nfmax »
Re: Dust free lab !
« Reply #6 on: July 30, 2018, 10:30:37 am »
Its mostly from outside. Main road is just out of the room window.
Re: Dust free lab !
« Reply #7 on: July 30, 2018, 10:32:16 am »
I will see in the local hardware stores if I find these brushes. I think I saw it to the building paint workers.
Offline Halcyon
  • Global Moderator
Re: Dust free lab !
« Reply #8 on: July 30, 2018, 11:03:34 am »
The best thing I ever bought was one of those Roomba robotic vacuum cleaners (one of the earlier models without all the IoT connected bullshit).
I have hardwood floors almost everywhere and I could vacuum manually using a traditional vacuum cleaner and the Roomba would still pick up a canister worth of dust. It's actually quite shocking how much stuff get's kicked up into the air and settles on floors and surfaces.
Every 2-3 days, I just let that thing go and I have noticed a significant decrease in the level of dust. It also gets under things where you would not normally vacuum properly.
Just make sure it can't get to any small components or USB cables as it'll take those along for a ride.
Offline mubes
  • Do Not Boil
Re: Dust free lab !
« Reply #9 on: July 30, 2018, 01:27:15 pm »
I have a similar irritation....and it doesn't matter how much you clean, dust still builds up. Currently exprimenting with a Levoit Air Purifier (See https://www.amazon.co.uk/gp/product/B071D58ZY5) but no conclusions yet....it's certainly collecting some crud in its filters though and I have the advantage that my study is relatively small (4m x 3m).
DAVE
Offline Fsck
  • sleep deprived
Re: Dust free lab !
« Reply #10 on: July 30, 2018, 01:29:20 pm »
I live in a shitty old apartment with crap filtering and insulation.
20" box fan + 20" furnace filters running all the time. The filters last like 1.5-2 months.
"This is a one line proof...if we start sufficiently far to the left."
Offline Lord of nothing
  • Country: at
Re: Dust free lab !
« Reply #11 on: July 30, 2018, 02:23:14 pm »
I bought one from Ebay.  :-+
Made in Japan, destroyed in Sulz im Wienerwald.
Offline babysitter
  • pushing silicon at work
Re: Dust free lab !
« Reply #12 on: July 30, 2018, 02:26:42 pm »
1. Seal it.
2. Clean it.
Do this and clean much less. You might be able to decrease 3. when the room is not in use.
Putting a box around your desk and doing a second stage positive pressure filtered air will help to keep the desk even cleaner.
I'm not a feature, I'm a bug! ARC DG3HDA
Offline LaserSteve
Re: Dust free lab !
« Reply #13 on: July 30, 2018, 02:42:10 pm »
I used to  use a Furnace filter 16x20" in a fame and a couple of 250 cfm muffin fans.  I used a high quality 3M "Filtrete" nanofiber based filter, rather then the $1.69  open weave variety.  I just let it circulate in the room space, I do not try to go positive pressure at all, but if I could I would filter and keep that space at a slightly higher pressure.   Use a small visible laser in the dark to quantify your dust levels and sources.
Steve
« Last Edit: July 30, 2018, 02:45:04 pm by LaserSteve »
"Programming is more than an important practical art. It is also a gigantic undertaking in the foundations of knowledge"
Adm. Grace Hopper
  • Country: at
Re: Dust free lab !
« Reply #14 on: July 30, 2018, 02:54:06 pm »
A cheap solution:
Maybe you can tax when you pay for food and so.
