Updated...
ok, figured this out, i found the last framework that had a firmware file for the 600 series is 2.6.4, so loaded that on and wiped what was there so it's blank now.
Had a play around with it, i can see how they are very powerful but you need a lot of planning to get the camera setup to do anything particularly interesting. I have had a play around with barcodes, edge detection etc
i have attached a few images of the framework software that configures the camera.
Basically it will configure the camera with sensors and products, products can be made up of multiple sensors to generate a pass/fail condition which the camera can either output on physical output lines or through serial or IP comms. You can have as many sensors and products as the camera has flash space for.
Once the camera is flashed with the program all the image processing is internal.
The images attached show
Edge Counting of the vents on the side of my cheapo bench PSU showing 18 edges (light+dark)
Zoomed version of above but now counting only light edges
Barcode of a can of Bud
Some OCR of lettering on the same can.
