Author Topic: Looking for obscure Hirose PCMCIA 68-pin card connector - NX30H-68P  (Read 670 times)
Online peter-hTopic starter
I believe that is the right P/N.
I am after the mating plug for the above connector. Or even a ribbon cable with the plug on it, which connects to all the pins. Just a one-off.
It is listed at various places but nobody stocks it.
Many thanks in advance for any pointers.
Re: Looking for obscure Hirose PCMCIA 68-pin card connector - NX30H-68P
« Reply #1 on: January 14, 2021, 04:37:35 pm »
It occurred to me that I can get a little PCB from some cheap chinese shop, which (if the thickness is right) will just push into that connector :)
« Reply #2 on: January 17, 2021, 03:28:44 pm »
Final update:
I found someone making a cable to plug into the card but it is about £400, so in an hour I did a PCB
and for $30 got JLCPCB to make it. Gold plated.
It is a very expensive ARINC429 card (4x IN 4x OUT, from MAXT) which I picked up on Ebay for €150. I don't even know if it works and neither did the seller. I suspect it listed at several k $.
