Author Topic: Soldering iron calibration/bad heater?  (Read 1498 times)
Offline XOIIO
« on: May 22, 2014, 01:11:45 pm »
Hey all, since I got a multimeter with a thermocouple I decided to check my soldering iron's true temp, I've used it at 450 C ever since I got it since it was second hand, turns out that was only around 230 C, talk about out of calibration! I'm working on calibrating it now, but it's proving finicky, I got it to stay at around 300, but when I turned it up the temp went down, so I'm still figuring it out. Is the heater perhaps dyeing out? There isn't much range on the trim pot. This is a hakko 936 by the way.
edit: thermocouple slipped off the iron, no wonder the temp went down a bit  :palm:
edit2: whoops, didn't delete the whole old title.
« Last Edit: May 22, 2014, 04:09:27 pm by XOIIO »
Offline dexters_lab
    • DextersLab2013
Re: Selsius/soldering iron calibration/bad heater?
« Reply #1 on: May 22, 2014, 01:36:43 pm »
maybe the same 'issue' i had with my Xytronic?
https://www.eevblog.com/forum/reviews/xytronic-lf-1000-soldering-station-calibration/
Mine wasn't that far out though
The size of the tip and the point your measuring affect it greatly, in a long and fine tip i would expect the error to be greater than a stumpy thick chisel tip for example
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools." - Douglas Adams
https://www.youtube.com/user/DextersLab2013
http://dexterslab2013.blogspot.co.uk/
Offline staxquad
  • Eye Candy
« Reply #2 on: May 22, 2014, 03:59:51 pm »
Authentic 63/37 is a eutectic alloy, which melts at exactly 183 °C  or 361.4 °F.
"TEPCO Fukushima you long time"
You say Vegemite, I say Yosemite. (Ve-gem-mit-tee, Yo-zey-might)
"For starters : you're Canadian...."
