Result of what? Can you summarize what is going on. It has been a long time.
I have bought camera and shooting gear to use in my videos, this video is the first using them. Panasonic HC v-770 camera + tripod + ball head + lav. microphone + USB microphone + other stuff = around 900$ or so xD.
Can you zoom in on the data sheets, I cannot read them.
Will do next time.
The voice over is perfectly fine. For me, the only slight issue (potentially) is the thunder logo sound. Is it louder than other sounds? I did not verify this, but a sudden "bang" could be problematic on headphones if it is loud.
I will try to adjust all sounds in next videos for sure. Personally, I love this thunder sound (especially this bang one) ever since I was a child!! yes, it is a famous one... first time hearing it was in Mortal Kombat defenders of the realm opening
after that I was hooked for life.
Also I suggest you name your videos like Dave does.
Actually, most reviews and channels do not suggest this. I was pro tagging like this but now I am not. Greatscott, afrotechmods and mikeselectricstuff for example, they don't use it. Actually, almost no channel use it except eevblog and some other ones like voltlog.
For eevblog it is now totally useless as I myself don't remember episodes number and will always revert back to searching the name for the one I want. dave chose the tagging for a reason, which is now not that important.
thanks for your advise.
