Author Topic: EEPROM Marking codes  (Read 606 times)
Offline zestiTopic starter
  • Country: pk
« on: April 22, 2024, 10:42:48 am »
Hi all,
New to this web site. I'm eltronics repair business and playing also with eeproms. Now I cam accross eeproms with starnge marking codes. And its hard to find them online. So need help, if any one could help out, like this eeprom with marking code AAY2F and Q935 below. Image is attached.
Thanks.
Offline wraper
  • Country: lv
Re: EEPROM Marking codes
« Reply #1 on: April 22, 2024, 10:52:24 am »
image is broken.
Offline Alex Eisenhut
  • Place text here.
« Reply #2 on: April 22, 2024, 12:21:46 pm »
File size shows as 0KB, something's wrong!
  • Country: pk
« Reply #3 on: April 22, 2024, 12:51:57 pm »
Sorry for attachment. I think I unplugged my mobile while tranferring. Thanks for notifying.
Offline amyk
« Reply #4 on: April 23, 2024, 02:00:40 am »
How sure are you that it's an EEPROM?
  • Country: pk
« Reply #5 on: April 23, 2024, 06:49:25 am »
That's on an HP printer drum unit life counter PCB.
Offline thm_w
  • Non-expert
« Reply #6 on: April 24, 2024, 08:31:54 pm »
If it can't be found online, most likely its a custom part number chosen by HP. Since they order mass amounts of these.
What you could do is connect to it with an eeprom programmer and try to detect what IC it is. Some have that functionality. Or map out the pinout and choose a similar part that matches up, then up the size until you start seeing the data loop and repeat.
I don't know if this is relevant: https://h30434.www3.hp.com/psg/attachments/psg/Printing/2868898/1/111reset.pdf
Offline DavidAlfa
« Reply #7 on: April 24, 2024, 08:46:20 pm »
Probably custom so you can't simply plug it to a CH341 and reset it.
  • Country: pk
« Reply #8 on: April 25, 2024, 09:23:57 am »
Yes , I was thinking the same. Will try and let you know. At least I can guess with pin layout of chip.
The link in not relevent, thanks anyways.
« Last Edit: April 25, 2024, 09:25:55 am by zesti »
