Author Topic: Engineering of duck tape and other adhesives  (Read 1328 times)
Offline mag_therm
Re: Engineering of duck tape and other adhesives
« Reply #25 on: May 27, 2024, 06:49:24 pm »
OK, Benta,
CryBaby GCB-95 ( The 95 was used from early days and is not the year)
Some age indications according to various internet forums:
Plastic gear glued to pot (earlier had a pin)
Pot is "Hot Potz 11"
Black inductor
9VDC adaptor socket  smaller than the hole in the casting, with negative to centre pin (later model?)
Green PCB
The most likely indication on this one is ( I think)  the date code "Mexico 9619"
on the pedal switch.
Along with CE label, I think it is a 1996.
« Last Edit: May 27, 2024, 06:50:59 pm by mag_therm »
Offline Benta
« Reply #26 on: May 27, 2024, 07:24:00 pm »
 I believe you.
