That's splendid! I'm fascinated by natural electrostatic effects, and hunt stories of them, but I'd never heard of this one.
Few people recognize how significant electrostatics are, on a planetary and interplanetary scale. Or know how much more powerful the electrostatic force is than gravity.
For a proton - electron pair, the gravitational attraction is 4.40*10^-40 times weaker than the electrostatic attraction. Ten to the minus 40 power.... Or inversely, electrostatics are ten to the 40th power stronger than gravity.
Different ratios for proton to proton, and electron to electron, due to different mass/charge ratios. But all in the same ballpark of "a lot of zeros."
The traditional explanation for how storm clouds generate the potential differences for lightning breakdowns, is that water droplets acquire charge, then up and down drafts in clouds separate charged groups of droplets. In other words saying that 'wind currents provide the energy for lightning.'
But personally I wouldn't be surprised if the underlying cause is the space-to-ground standing potential difference (which originates from Solar Wind current effects), and that a lot of the charge movement and air movements in clouds is due to charges being pushed around by the main space to ground electrostatic gradient. So, the other way round. The space-ground electrostatic gradient provides most of the energy, with cloud short-range air currents partially a secondary effect. ie mostly caused by density/thermal gradients, but also significantly influenced by electrostatic forces.
In those videos you see a very direct illustration of the constantly varying atmospheric currents and resulting electric field variations. Really neat! Thanks for posting.
