Author Topic: New House: How to tell which cableoutlet goes to which line?  (Read 1193 times)
Offline BeaminTopic starter
  • If you think my Boobs are big you should see my ba
« on: August 20, 2017, 09:38:21 pm »
I moved into this new house that has about 10 bed rooms. Its less then 10 years old and as far as I can tell;
It was built with for cable TV RG6
It was later upgraded to a satellite But not sure where the TVs were the wiring has been hacked by Verizon.
It was wired for fios a few years ago. TERRIBLE job everything was just hacked apart and rushed. Instead of connectors there are just holes drilled; with eithernet and cables shoved through them. It looks like there was last two TV's.
So there is one bed room I want the fios TV to travel down the RG6 up to.
How do I tell which cable from the outside goes to the bundle of cables outside the house. Trying to connect a cable box to the room and playing around with cables out side is not really an option because I don't know if the source signal is really working. How would the people that work for the company trace the wires assuming there is nothing hooked up? Almost like I need to do a continuity test with 100's of feet of leads which is not practical.
« Last Edit: August 20, 2017, 09:39:57 pm by Beamin »
Max characters: 300; characters remaining: 191
Images in your signature must be no greater than 500x25 pixels
Offline elecman14
Re: New House: How to tell which cableoutlet goes to which line?
« Reply #1 on: August 20, 2017, 09:55:50 pm »
Cheapest way is to disconnect the cables where they come in at the street. Then Short the copper wire in the middle of the F connector to the outer shell. Then measure the bundle at the other end for the short. If you do this one at a time it would be possible to map the cables. If that seems complicated something like Klein Tools VDV512-058 should do the trick.
« Reply #2 on: August 20, 2017, 10:19:19 pm »
That's what I was thinking, I didn't want to hack up the cables more but my OCD is going to lead to me redoing that anyways.
