Author Topic: Electroboom, busting the appliance in the tub will kill you myth.  (Read 8740 times)
Offline StonentTopic starter
One day I think his youtube channel will just stop updating.  That's when you know he's gone too far and killed himself.
Offline digsys
    • DIGSYS
Re: Electroboom, busting the appliance in the tub will kill you myth.
« Reply #1 on: November 19, 2013, 11:12:50 am »
It's pretty sad when you're not watching it for any technical content, but keep whispering .. please .. please .. please ..
« Reply #2 on: November 19, 2013, 11:19:25 am »
Well I did find the testing of the water with the volt meter and lighting the LED interesting.
Offline amyk
« Reply #3 on: November 19, 2013, 01:40:15 pm »
:o
The electrolysis products were probably more dangerous than the electricity...
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #4 on: November 19, 2013, 03:16:16 pm »
The guy is either nuts, or he knows exactly what is doing, but its painfull to see him putting his fingers in the water  :wtf:
« Reply #5 on: November 19, 2013, 08:20:14 pm »
:o
I had to wonder when he said he didn't know what was going on with that. I've made some pretty noxious chlorine with just batteries, salt water and a coke bottle.
120V seems like it would do a lot.
Offline AndyC_772
« Reply #6 on: November 19, 2013, 08:29:42 pm »
Dumb question time... if there's a simple answer to this then I'll claim excessive tiredness due to my hectic engineer's social life:
Why did only one of the wires get eaten away during the process? If it's plugged into the ac mains, and the polarity of the two wires keeps reversing, surely whatever electrolytic effect happens at one wire will happen at the other during the other half cycle?
Why was the effect on the wires not symmetrical?
Offline rolycat
« Reply #7 on: November 19, 2013, 08:34:06 pm »
:o
But with 120V AC, the anode and the cathode are constantly swapping places, so whatever reactions take place are going to be very messy and largely unproductive.  Mehdi may have been expressing that, or he may have been reinforcing his hilariously incompetent vblog persona.
A possible answer to AndyC_772's question is that both wires were corroded, but one happened to break off at the insulation before the other.
« Reply #8 on: November 19, 2013, 09:25:05 pm »
Of course who could forget the classic moment that started this question.
Offline smashedProton
« Reply #9 on: November 20, 2013, 03:05:10 am »
The bubbles were chlorine...
He was dipping his hand in sodium hydroxide...
http://www.garrettbaldwin.com/
Invention, my dear friends, is 93% perspiration, 6% electricity, 4% evaporation, and 2% butterscotch ripple.
Offline amyk
« Reply #10 on: November 20, 2013, 08:44:23 am »
I'm not too familiar with chemistry but since the electrodes are alternating wouldn't the hydrogen just combine with the chlorine and give HCl... which immediately dissolves into the water again?
« Reply #11 on: November 20, 2013, 09:00:09 am »
There would be a source of energy required to rejoin the H and Cl, if he were to hold a lit match over it, there would be popping from H joining with O2 and H joining with Cl. The HCl that didn't splatter or go off as vapor would go in the water and neutralize with the NaOH and become salt water again.
The murky-ness of the water was likely Copper(II) Chloride and also Copper Oxychloride which precipitates out when Copper(II) Chloride reacts with NaOH.
« Last Edit: November 20, 2013, 09:04:42 am by Stonent »
« Reply #12 on: November 20, 2013, 02:28:10 pm »
Copper(2) chloride is blue
Offline JackOfVA
« Reply #13 on: November 20, 2013, 02:56:18 pm »
Leidenfrost effect demonstrations are worse - stick your finger in water, so that it is completely wet. Then stick your wet finger into a solder pot full of molten solder.  The Leidenfrost effect lets you do this without harm, but it doesn't take much to go wrong before it becomes a disaster.
Offline rolycat
« Reply #14 on: November 20, 2013, 03:29:54 pm »
Thanks to the same effect working in reverse, you can also dip your (dry) hand into a flask of liquid nitrogen at -196 °C.
Unfortunately I was told this while working in a biochemistry lab which had copious supplies of the stuff, and was young and stupid enough to try it. Fortunately nothing went wrong and my hand survived the ordeal.
Offline Shock
« Reply #15 on: November 21, 2013, 05:16:21 am »
Fearing the risk of a mercury explosion cloud in my microwave...
The other day I put a compact fluro tube with its electrodes exposed (submerged in shallow dish of water) for 10 seconds on high.
Lighted like a Christmas tree.  Not an experiment I will repeat but worth it.
Offline Alexei.Polkhanov
« Reply #16 on: November 21, 2013, 06:01:35 am »
Yup and and hydrogen:
2NaCl + 2H2O ? Cl2 + H2 + 2NaOH
Offline Terabyte2007
  • It is purpose that created us... That defines us..
« Reply #17 on: November 21, 2013, 11:46:24 am »
Not to mention the inhalation danger of gases produced by the Copper Chloride.
Eric Haney, MCSE, EE, DMC-D
Electronics Designer, Prototype Builder
Offline G7PSK
  • It is hot until proved not.
« Reply #18 on: November 21, 2013, 02:27:33 pm »
You don't need any water even a tube with the filaments burnt out will light up super bright in a microwave, done that many times to demonstrate it to non-believers.
Offline strangelovemd12
« Reply #19 on: November 21, 2013, 06:18:43 pm »
For those interested in the electrolysis going on, there is a fun little paper by NASA showing kids how to make chlorine gas:
http://aquarius.nasa.gov/pdfs/electrolysis.pdf
Also note that electrolysis on molten salt is a nifty way to get that big chunk of sodium you've always wanted.
Please hit my ignorance with a big stick.
« Reply #20 on: November 21, 2013, 07:40:18 pm »
Better do that in a very dry atmosphere though, otherwise you get it all coming apart with humidity.
Offline Zero999
  • 0999
« Reply #21 on: November 21, 2013, 11:46:26 pm »
I've thought about this before: you're very unlikely to be electrocuted if you're in the bath and someone throws an electrical appliance in the water in modern installations where an RCD is mandatory, I'd suspect it's impossible.
