Author Topic: Typst, simple markup language for documentation  (Read 4211 times)
Offline PicuinoTopic starter
    • Picuino
Re: Typst, simple markup language for documentation
« Reply #25 on: September 21, 2026, 02:11:59 pm »
Two pages of exercises with more difficult layout (sorry for the translation mistakes).
Try doing this in Word, ASCIIDOC or LaTeX, and it'll take you three times as long (if you even manage to get this layout in the end).
A single dataset can be used to create two tables (on the first sheet, the even rows are hidden, and on the second sheet, the odd rows are hidden, so that each side of the sheet is the solution to the other side of the sheet). This makes it easier to check for and correct errors.
Typst code:
// PAGE CONFIGURATION
#set page(
  paper: "a4",
  margin: (top: 10mm, bottom: 8mm, left: 10mm, right: 10mm ),
  columns: 2,
#set columns(
  gutter: 6mm
#set text(
  font: "Liberation Sans",
  lang: "en",
  hyphenate: true
#set par(
  justify: true
#show table.cell: set text(weight: "bold")
#show link: set text(fill: blue.darken(80%))
// DATA
#let datos = (
  ([4.7 M#sym.Omega], [YELLOW], [VIOLET], [GREEN], [GOLD], [1.91 μA]),
  ([22 #sym.Omega], [RED], [RED], [BLACK], [GOLD], [409 mA]),
  ([15 #sym.Omega], [BROWN], [GREEN], [BLACK], [GOLD], [600 mA]),
  ([3.3 #sym.Omega], [ORANGE], [ORANGE], [GOLD], [GOLD], [2.73 A]),
  ([10 k#sym.Omega], [BROWN], [BLACK], [ORANGE], [GOLD], [900 μA]),
  ([150 #sym.Omega], [BROWN], [GREEN], [BROWN], [GOLD], [60.0 mA]),
  ([220 #sym.Omega], [RED], [RED], [BROWN], [GOLD], [40.9 mA]),
  ([47 #sym.Omega], [YELLOW], [VIOLET], [BLACK], [GOLD], [192 mA]),
  ([3.3 k#sym.Omega], [ORANGE], [ORANGE], [RED], [GOLD], [2.73 mA]),
  ([2.2 k#sym.Omega], [RED], [RED], [RED], [GOLD], [4.09 mA]),
  ([100 #sym.Omega], [BROWN], [BLACK], [BROWN], [GOLD], [90.0 mA]),
  ([680 #sym.Omega], [BLUE], [GREY], [BROWN], [GOLD], [13.2 mA]),
  ([22 k#sym.Omega], [RED], [RED], [ORANGE], [GOLD], [409 μA]),
  ([100 k#sym.Omega], [BROWN], [BLACK], [YELLOW], [GOLD], [90.0 μA]),
  ([1.0 #sym.Omega], [BROWN], [BLACK], [GOLD], [GOLD], [9.00 A]),
  ([68 k#sym.Omega], [BLUE], [GREY], [ORANGE], [GOLD], [132 μA]),
  ([680 k#sym.Omega], [BLUE], [GREY], [YELLOW], [GOLD], [13.2 μA]),
  ([3.3 M#sym.Omega], [ORANGE], [ORANGE], [GREEN], [GOLD], [2.73 μA]),
  ([1.5 k#sym.Omega], [BROWN], [GREEN], [RED], [GOLD], [6.00 mA]),
  ([4.7 k#sym.Omega], [YELLOW], [VIOLET], [RED], [GOLD], [1.91 mA]),
  ([2.2 #sym.Omega], [RED], [RED], [GOLD], [GOLD], [4.09 A]),
  ([10 #sym.Omega], [BROWN], [BLACK], [BLACK], [GOLD], [900 mA]),
  ([2.2 M#sym.Omega], [RED], [RED], [GREEN], [GOLD], [4.09 μA]),
  ([15 k#sym.Omega], [BROWN], [GREEN], [ORANGE], [GOLD], [600 μA]),
  ([330 k#sym.Omega], [ORANGE], [ORANGE], [YELLOW], [GOLD], [27.3 μA]),
  ([220 k#sym.Omega], [RED], [RED], [YELLOW], [GOLD], [40.9 μA]),
  ([4.7 #sym.Omega], [YELLOW], [VIOLET], [GOLD], [GOLD], [1.91 A]),
  ([6.8 M#sym.Omega], [BLUE], [GREY], [GREEN], [GOLD], [1.32 μA]),
  ([470 #sym.Omega], [YELLOW], [VIOLET], [BROWN], [GOLD], [19.2 mA]),
  ([1.0 k#sym.Omega], [BROWN], [BLACK], [RED], [GOLD], [9.00 mA]),
  ([47 k#sym.Omega], [YELLOW], [VIOLET], [ORANGE], [GOLD], [192 μA]),
  ([1.5 #sym.Omega], [BROWN], [GREEN], [GOLD], [GOLD], [6.00 A]),
  ([33 #sym.Omega], [ORANGE], [ORANGE], [BLACK], [GOLD], [273 mA]),
  ([1.5 M#sym.Omega], [BROWN], [GREEN], [GREEN], [GOLD], [6.00 μA]),
  ([150 k#sym.Omega], [BROWN], [GREEN], [YELLOW], [GOLD], [60.0 μA]),
  ([6.8 #sym.Omega], [BLUE], [GREY], [GOLD], [GOLD], [1.32 A]),
  ([68 #sym.Omega], [BLUE], [GREY], [BLACK], [GOLD], [132 mA]),
  ([330 #sym.Omega], [ORANGE], [ORANGE], [BROWN], [GOLD], [27.3 mA]),
  ([1.0 M#sym.Omega], [BROWN], [BLACK], [GREEN], [GOLD], [9.00 μA]),
  ([33 k#sym.Omega], [ORANGE], [ORANGE], [ORANGE], [GOLD], [273 μA]),
  ([6.8 k#sym.Omega], [BLUE], [GREY], [RED], [GOLD], [1.32 mA]),
  ([470 k#sym.Omega], [YELLOW], [VIOLET], [YELLOW], [GOLD], [19.2 μA])
#let datos-inicio = datos.slice(0, 10)
#let datos-fin = datos.slice(10)
// DEFINITIONS
#let encabezado() = [
  #align(center)[
    #title[
      #link("https://www.picuino.com/en/electronic-codigo-colores.html")[
        COLOR CODING \ FOR RESISTORS
    #image("electronic-resistor-02.en.png", width: 70mm)
    #link("https://creativecommons.org/licenses/by-sa/4.0/")[*License CC BY-SA 4.0*]
    #h(12mm)
    #link("https://picuino.com/en/index.html")[*www.picuino.com*]
  - Calculate the missing colors and resistors in the following tables.
  - In the last column, calculate the current that will flow through the
    resistor when connected to a 9 volt battery.
  - All values should be written to 3 decimal places and with the
    multiplier symbol that best corresponds to it
    (M=Mega, k=kilo, m=mili, μ=micro)
#let tabla-colores() = [
  #set text(size: 10pt)
  #table(
    columns: (3fr, 2fr, 3fr, 2fr),
    align: center + horizon,
    rows: (10mm,) + (5mm,) * 11,
    fill: (x, y) => if y == 0 { rgb("d0d0d0") } else { none },
    table.header(
      [COLOR], [VALUE], [MULTIPLIER], [TOLERANCE],
    [BLACK],   [0],   [x 1],         [],
    [BROWN],   [1],   [x 10],        [#sym.plus.minus 1%],
    [RED],     [2],   [x 100],       [#sym.plus.minus 2%],
    [ORANGE],  [3],   [x 1000],      [],
    [YELLOW],  [4],   [x 10 000],    [],
    [GREEN],   [5],   [x 100 000],   [],
    [BLUE],    [6],   [x 1000 000],  [],
    [VIOLET],  [7],   [],            [],
    [GREY],    [8],   [],            [],
    [WHITE],   [9],   [],            [],
    [GOLD],    [],    [x 0.1],       [#sym.plus.minus 5%],
// CONTENT
#encabezado()
#tabla-colores()
#v(1fr)
#v(5mm)
#block[
  #align(center)[== COMMERCIAL SERIES E6: (5%)]
  #set text(size: 9pt)
  #set par(leading: 4pt)
  #show table.cell: it => {
    if ((it.x == 0 and calc.even(it.y) and it.y > 0) or
       (it.x > 0 and calc.odd(it.y) and it.y > 0)) {
      hide(it)
    } else { it }
  #table(
    columns: (1fr, 1fr, 1fr, 1fr, 1fr, 1.2fr),
    rows: (8.44mm,) + (8.44mm,) * datos-inicio.len(),
    inset: 0.6mm,
    fill: (x, y) =>
      if y == 0 {
        rgb("e0e0e0")
      } else {
        if ((x == 0 and calc.even(y)) or (x > 0 and calc.odd(y))) {
          rgb("ccffff")
        } else { none }
    table.header(
      [Value #sym.Omega], [Stripe 1], [Stripe 2], [Stripe 3], [Stripe 4], [I = 9V / R],
    ..datos-inicio.flatten()
  #colbreak()
  #table(
    rows: (8.44mm,) + (1fr,) * datos-fin.len(),
    inset: 0.6mm,
    fill: (x, y) =>
      if y == 0 {
        rgb("e0e0e0")
      } else {
          rgb("ccffff")
        } else { none }
    table.header(
    ..datos-fin.flatten()
// PAGE 2
#encabezado()
#tabla-colores()
#v(1fr)
#v(5mm)
#block[
    if ((it.x == 0 and calc.odd(it.y) and it.y > 0) or
       (it.x > 0 and calc.even(it.y) and it.y > 0)) {
      hide(it)
    } else { it }
  #table(
    inset: 0.6mm,
    fill: (x, y) =>
      if y == 0 {
        rgb("e0e0e0")
      } else {
        if ((x == 0 and calc.odd(y)) or (x > 0 and calc.even(y))) {
          rgb("ccffff")
        } else { none }
    table.header(
  #colbreak()
  #table(
    inset: 0.6mm,
    fill: (x, y) =>
      if y == 0 {
        rgb("e0e0e0")
      } else {
          rgb("ccffff")
        } else { none }
    table.header(
« Last Edit: September 21, 2026, 02:41:56 pm by Picuino »
    • Picuino
« Reply #26 on: October 09, 2026, 08:16:25 pm »
The following users thanked this post: xvr
