Author Topic: Electronics repair channels on YouTube - recommendations?  (Read 10894 times)
Offline nightfire
Re: Electronics repair channels on YouTube - recommendations?
« Reply #25 on: March 15, 2023, 09:13:29 pm »
Well, in addition to the already mentioned channels, I sometimes like to watch:
https://www.youtube.com/@LearnElectronicsRepair  - some oldschoold methods for diagnosis, mostly with an old Fluke 77
https://www.youtube.com/@electronicsrepairschool  - also some classic methods for diag of issues, with good explanations
The following users thanked this post: SolderSucker
Offline andy3055
« Reply #26 on: March 15, 2023, 09:20:06 pm »
https://m.youtube.com/@w2aew
Alan is great.  He has some clips on basic stuff and all the way to using scopes and other test equipment and how to use them for different things.
Very informative stuff on his back to basics series. I believe he is ex Tectronix.
Mr. Carlson is great as well. If you join his Patreon page, you get access to test equipment he designs. Great stuff.
« Last Edit: March 15, 2023, 09:28:26 pm by andy3055 »
Offline carpelux
« Reply #27 on: March 15, 2023, 09:29:54 pm »
Electronics Old and new by Manuel Caldeira
https://www.youtube.com/@electronicsoldandnew/about
Lots of restaurations on tube radios and some good test equipmet projects.
Catch the light
The following users thanked this post: SolderSucker, Smoky
Offline Howardlong
« Reply #28 on: March 16, 2023, 11:08:48 pm »
Mend It Mark - only recently found this guy and love his channel - he's informative, entertaining and does some really nice work (https://www.youtube.com/@MendItMark )
Agreed, his channel popped up a few days ago in my Youtube feed.
It's really well produced, and I have no idea how he manages to chuckle all the time, and keep his perma smile. I wasn't sure if I'd tire of it, but I've found quite the opposite. It's total nerd entertainment. He has a great workshop too, with a good proportion of his TE being middle aged if not older, showing that you don't need the latest gear to be productive.
I think I might suggest that he invests in soldering tweezers for the SMD work he does.
His biggest crime (tongue deeply embedded in cheek) is he still uses that manky old solder sucker: I haven't used one of those for 30 years!
I find his videos highly entertaining and educational, but then I am a total nerd.
Offline alm
« Reply #29 on: March 17, 2023, 11:17:13 am »
One that I recently found, I didn't see posted here before, and quite like for his in depth repairs, is Martian Tech. Mainly test equipment and vintage computers. I guess they only have vintage stuff on Mars ;)
https://youtube.com/@MartianTech
Offline JohanH
« Reply #30 on: March 17, 2023, 12:01:09 pm »
DiodeGoneWild has special humor and lives up to his name.
One not yet mentioned is also NFM with many repair videos.
Androkavo has these super educational soldering videos.
Defpom wasn't mentioned yet. Has some good repair videos.
SDG Electronics is your favorite forum solder equipment tester. Has many some repair videos as well.
« Last Edit: March 17, 2023, 03:09:09 pm by JohanH »
The following users thanked this post: newbrain, TheDefpom, SolderSucker, I wanted a rude username
Offline fenugrec
« Reply #31 on: March 17, 2023, 01:38:50 pm »
As long as we're ok with self-promotion... I have a handful of repair videos up https://www.youtube.com/@fenugrec5697/videos , probably ranks me in the bottom 1% of the barrel - fine with me, just sharing less-common repairs.
Not everybody has Shariar's luck and buys some busted-up TE where the only problem is a bad N connector or disconnected harness : ))
Offline HwAoRrDk
« Reply #32 on: March 17, 2023, 02:57:26 pm »
SDG Electronics is your favorite forum solder equipment tester. Has many repair videos as well.
I'm not sure what your definition of "many" is, because Steve's done only a handful of repair videos in the last few years. While his channel is excellent, Steve doesn't really do repairs; his channel is mostly focused on circuit design and build, as well as equipment review.
Offline nigelwright7557
    • Electronic controls
« Reply #33 on: March 17, 2023, 03:00:58 pm »
I watch north ridge fix a bit.
In the end it gets a bit same old thing.
He doesnt often use circuit diagrams but more of a look for damage, test power mosfets for shorts.
He is very skilled at fixing ripped connectors with patches.
Offline JohanH
« Reply #34 on: March 17, 2023, 03:09:32 pm »
Thanks, corrected.
Offline SolderSuckerTopic starter
« Reply #35 on: March 17, 2023, 04:25:39 pm »
Just had a look at some of his videos - great stuff, have subscribed. Thanks for the recommendation.
The following users thanked this post: TheDefpom
Offline vk6zgo
« Reply #36 on: March 17, 2023, 04:38:58 pm »
I'll probably get some crap for this, but I find Shango066's channel very entertaining.  The focus is primarily on getting old tube televisions, radios and hifi systems that have been sitting out in the weather for decades running well enough to watch or listen (as opposed to restoration).  He does this with a bare minimum of equipment, and often tests capacitors by running an audio signal through them and judging their health by the frequency filtering listening to the amplified signal.
Will you learn electronic theory? No.  Will you be entertained? Yes  :P  That said, I did pick up a few things watching him work on transistorized radios.
EDIT - seconding Mr. Carlson, CuriousMarc and Adrian's Digital Basement.  +12voltvids
AvE is also a hysterical smart guy, tends to deal with the mechanical side of electrical stuff.
Sorry, I find shango066 intensely annoying.
He makes comments which are technically wrong, blunders around & more by blind luck than anything else, "sort of" fixes things.
The following users thanked this post: quadtech
Offline vk6zgo
« Reply #37 on: March 17, 2023, 04:46:11 pm »
JOSE V. GAVILA - EB5AGV doesn't seem to do videos, but his website is excellent.
He describes his repairs to ham radio stuff, test equpment, & some other things.
His TE collection is worth looking at in itself.
Offline gamalot
  • Correct my English
    • Youtube
« Reply #38 on: March 17, 2023, 04:49:51 pm »
A girl who knows how to use a soldering iron properly
https://www.youtube.com/@FazioElectric
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
Offline unknownparticle
« Reply #39 on: March 17, 2023, 05:40:22 pm »
learn electronics repair
Self explanatory!  The guy runs an electronics repair business, in the Canaries I think (!!), repairs a wide spectrum of equipment and devices, builds projects, reviews the odd equipment, does tutorials on repair techniques, hints and tips, etc, etc.
mend it mark
repairs a wide range of equipment, from valve to the latest gear, good presentation style, no blathering or messing about, very experienced guy, has a great array of test equipment!
DC coupling is the devils work!!
The following users thanked this post: SolderSucker, armandine2
« Reply #40 on: March 21, 2023, 12:23:15 am »
Our member Defpom:
https://www.youtube.com/@TheDefpom/videos
Likes collecting old TE and fixing it for himself or sale.
His livestreams and chat can be quite interesting.
Online paulca
« Reply #41 on: April 01, 2023, 09:38:40 am »
+1 for Mend-It-Mark
The following users thanked this post: SolderSucker, S. Petrukhin
Offline Neepa
  • Mechanic by trade Electronics enthusiast by choice
« Reply #42 on: April 01, 2023, 04:42:20 pm »
There is also xraytonyb: https://www.youtube.com/@xraytonyb
Mostly does audio repairs. Hour long deep dives like Mr. Carlson with some vintage test equipment refurb on the side. Also some tutorials from time to time like receiver alignment. Yt strictly is a hobby for him. As the name implies a guy owning an Medical Equipment/Xray machine service company.
Turbojet Mechanic playing EE.
The following users thanked this post: Smoky
Offline Shock
« Reply #43 on: April 02, 2023, 11:42:01 am »
Guys there is already a large sticky list of electronics related youtube channels in the "other blogs" forum. Ez24 is not actively posting at the moment. FanOfeeDIY offered in the past to maintain it if required. Perhaps you should be posting and adding the new ones to the list there.
Electronics related youtube channels:
https://www.eevblog.com/forum/other-blog-specific/a/
Repair related Books/Magazines/DVDs:
https://www.eevblog.com/forum/repair/repair-and-service-books-magazines-dvds/
« Last Edit: April 02, 2023, 11:57:46 am by Shock »
« Reply #44 on: February 18, 2024, 09:35:53 am »
Here's another great channel to add to the list:
https://www.youtube.com/@ThatElectronicsFool
Offline amyk
« Reply #45 on: February 18, 2024, 09:56:13 am »
Those who watch 12voltvids will probably also be interested in https://www.youtube.com/@norcal715 - mainly AV equipment repair.
Offline armandine2
« Reply #46 on: February 18, 2024, 07:27:34 pm »
.. not that I'm a computer person [I'm not] but I like Adamant IT and Paul Daniels, not sure why these two - but they seem to enjoy it.
In a closed society where everybody's guilty, the only crime is getting caught - Hunter S Thompson
« Reply #47 on: May 08, 2024, 09:37:43 am »
I used to watch a lot of northridgefix.
Problems tend to be capacitors and mosfets a lot of the time with the occasional chip failure.
His thermal camera does a lot of the debugging for him.
He must have patience to fix all the ripped connectors when he repairs broken pads.
Offline S. Petrukhin
  • Country: ru
« Reply #48 on: May 08, 2024, 10:42:54 am »
I like this guy from the UK. Charming man, golden hands, interesting repairs. https://www.youtube.com/@MendItMark
If you understand Russian or use yandex browser to translate on the fly, a soul channel.  https://www.youtube.com/@DMITRY_KORZHEVSKY
Both channels give rest.  :)
And sorry for my English.
Offline Shock
« Reply #49 on: May 08, 2024, 12:36:35 pm »
The following users thanked this post: S. Petrukhin
