Author Topic: Embed YouTube video code?  (Read 6783 times)
Offline rx8pilotTopic starter
« on: November 11, 2015, 08:51:27 pm »
Anyone know what code to use to embed a video in a post?
I tried a number of things I found by Google, but was unable to get a video embedded.
Offline apelly
  • Probe
Re: Embed YouTube video code?
« Reply #1 on: November 11, 2015, 08:55:44 pm »
I think you should see by quoting a post which has embedded youtube
The following users thanked this post: BatGroupCraft
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #2 on: November 11, 2015, 08:56:58 pm »
Simply make the [ url ] tags and put the full video link inbetween.
Alternatively, if you just want to link the video, no preview, use a url shortener service:
like this
Try to quote my message to see how I've done it.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
« Reply #3 on: November 11, 2015, 09:00:15 pm »
Tried this code....
[html]
<iframe width="560" height="315" src="https://www.youtube.com/embed/n3T007W-IAg?rel=0" frameborder="0" allowfullscreen></iframe>
[/html]
Like this one....
https://www.eevblog.com/forum/index.php?action=post;quote=797901;topic=58228.0
I see code that looks like this.....but it does not seem to work in my post.
[url=https://www.youtube.com/watch?v=cGxUXg1fQCs]https://www.youtube.com/watch?v=cGxUXg1fQCs[/url]
[/quote]
« Reply #4 on: November 11, 2015, 09:05:00 pm »
Ahhh, I think I got it now. The preview function does not seem to work, but when I post, it all works.
Thanks!
Offline Dave
  • Country: si
« Reply #5 on: November 11, 2015, 09:05:09 pm »
Ah, the quote apparently changes it. Let's try this way (I put tiny spaces to avoid making actual URL tags):
[url ]https://www.youtube.com/watch?v=cGxUXg1fQCs[/url ]
Offline Augustus
« Reply #6 on: November 11, 2015, 09:05:22 pm »
No tags needed, just paste the yt video url without anything else...
Greetings from the Black Forest, Germany
« Reply #7 on: November 11, 2015, 09:12:39 pm »
That is quicker and it was my first try.....the Preview option was not working so I thought I was doing it wrong. Should have been brave and just posted it.  |O
Offline EEVblog
« Reply #8 on: November 11, 2015, 11:13:30 pm »
Just paste the URL
This forum has a plugin installed that detects Youtube URLs and converts it into an embedded player.
The following users thanked this post: cdev, Harshadb13, Microdoser
« Reply #9 on: November 11, 2015, 11:16:19 pm »
Clearly, I was searching for the hardest possible solution.  |O
The following users thanked this post: tooki, Harshadb13
Offline Harshadb13
  • Country: in
  • A DIY electronics enthusiast
    • My Instructables
« Reply #10 on: March 20, 2021, 02:01:14 pm »
Hey!
Thanks for the info
Just pasted this post for a test
Offline JohnnyMalaria
    • Enlighten Scientific LLC
« Reply #11 on: March 20, 2021, 02:09:44 pm »
You have to use the full YT URL for it to show automatically in a post. e.g.,
https://youtu.be/FZN0PBBzEHw <- this is the short form and doesn't work
This is the full form for the same video (I just pasted the full URL, no tags etc):
The following users thanked this post: Harshadb13
Offline Harshadb13
  • Country: in
    • My Instructables
« Reply #12 on: March 20, 2021, 06:15:24 pm »
This was helpful.
Thanks
Offline cdev
« Reply #13 on: March 21, 2021, 01:04:07 am »
There is more to the embedding/streaming process than many people think. Especially seek in a video, that requires some behind the scenes magic. The HTML 5 spec and modern browsers make it a lot easier.
As Dave says, his blog CMS software creates a youtube "player" in the web page whenever it sees a raw YouTube URL.
That sure is nice. Your @eevblog videos sure are looking good these days. Crisp, they convey an awful lot of info.
« Last Edit: March 21, 2021, 01:07:07 am by cdev »
Offline Harshadb13
  • Country: in
    • My Instructables
« Reply #14 on: March 21, 2021, 07:38:30 am »
That's true.
But people like me struggle with python
HTML is out of question
Offline cdev
« Reply #15 on: March 21, 2021, 03:06:59 pm »
No its not, we can get you started right now.
Do you have a machine you can run a web server on? Even a Raspberry pi will do fine. We can save the files on a SD card.
I can walk you through getting a development machine set up. Its more useful to use a web server than files on your local disk for a number of reasons. There is a site w3schools.com that has extensive learning HTML resources.
The HTML used by youtube or other video hosting sites can be deconstructed to see how the controls work.
Its much easier once you do it and see it working, then some psychological barrier is broken and you just start getting your hands wet, seeing it work,  and its suddenly fun. When you see a site that uses some feature you like, just save everything to a folder.. everything you can grab. the tool "wget" is useful for this. Graphics can be done using free software tools like Gimp and Inkscape. And you need a text editor that you like. What platform do you want to use for authoring?
No Python required for basic HTML, I promise. I learned HTML from a few basic documents written by Tim Berners-Lee in the early 90s. Back then HTML was so simple small children could understand it and did. They could be creating hyperlinks in 15 minutes.
Nothing is more fun than teaching HTML to children. If they can use a computer they can write HTML. Most HTML is rarely used. Don't be intimidated by all that stuff.
« Last Edit: March 21, 2021, 03:23:43 pm by cdev »
Offline cdev
« Reply #16 on: March 21, 2021, 03:21:28 pm »
Hypertext is a more natural form of writing than flat text (files)
You can convey thoughts with more fidelity to their meanings.
At least I think so.
Offline Harshadb13
  • Country: in
    • My Instructables
« Reply #17 on: March 22, 2021, 04:31:29 am »
Thanks lot for your support.
But I'm a mechanical engineer and will probably never need HTML
Offline cdev
« Reply #18 on: March 24, 2021, 09:13:01 pm »
Maybe.
But I used to say that about SQL way back in the 80s, but when I got into it I found I liked it a lot and could do all sorts of useful stuff with it. A real swiss army knife..
« Last Edit: March 24, 2021, 09:16:18 pm by cdev »
Offline Harshadb13
  • Country: in
    • My Instructables
« Reply #19 on: March 25, 2021, 04:09:12 pm »
Maybe.
I did like SQL :-DD :-DD
did a small course on Coursera which had SQL
