Of course the super high end photo printers are inkjet and will be better but I'm comparing SOHO stuff here. In these cases laserjet always wins.
No, it doesn't. Inkjet will pretty much always beat laser in color.
InkJet beats SOHO B&W as well. Epson *original* T664 70ml black ink for 7500 page yield: 12.5$. I do not see how SOHO LaserJet *original* supplies can be any cheaper than that.
Well, that's the 4500 page cartridge, but even so your point stands!!
The German computer magazien C't did
an article (paywall, sorry!) about black and white office printers a few months ago, and the hands-down lowest page cost is an Epson inkjet.
Only IF you print in enough volume to actually get close to that yield. Inkjet always fails for occasional printing, more is wasted on cleaning cycles and you never get close to that kind of yield - if you are able to use the full ink capacity and it doesn't dry out in the cartridge before it's all used up. Print frequently, on a daily basis, and I may agree. Print occasionally, and the waste factor is insanely high.
It depends on how "occasional" it is, really. As I said in a prior comment, usually printing once a week is enough to prevent needing any wasteful deep cleaning.
Actually - the BEST color printers were those good old Tek dye sublimation ones. Let's not talk about cost per page. We had one of those at the company I worked for over 25 years ago. Amazing photo quality output. They were touchy though, we were always fixing it. I think it was on the orders of dollars per page.
Well, great for photos, but not so great for graphics. I think modern photo inkjets exceed the color quality of those dye-sub printers, while providing better sharpness.
And the best thing we had for making overheads - one of those wax printers, I think that was a Tek product as well. Very thoughtful design, not only was each stick a unique color, they also had unique shapes so even if you were colorblind you could put the 3 colors plus black int he correct slots when refilling it. It was weird on paper, and you could scratch the printing off, but for transparencies for the overhead project t the color was phenomenal. Very much a stained glass effect.
Those were the Tektronix, later Xerox, Phaser models, towards the end the 8000 series. (Other Phaser models are laser.) They were neat in many ways. And yeah, they were good for transparency, but (aqueous dye) inkjet is better, frankly. Transparencies are really the thing where color laser sucks, because the pigments in the toner block light without coloring it, so your lovely transparency that looks like color simply projects as black-and-white! Dye inkjet looks amazing.
They had a fairly high waste ratio as well, there was a waste wax drawer you had to empty periodically as it built up with the excess. And startup time for first page from power on seemed like forever as it had to melt the wax.
"Fairly high" is an understatement. The wax inkjets not only had to melt the wax, but the startup process used
insane amounts of ink. A single power up would use
1/8 of a cube of ink of each color! So these printers only made sense for high-volume printing with little downtime, since you didn't
ever want to shut them down, but their idle energy use is quite high due to needing to keep the wax molten. (Around 50W.) Of course, these were priced out of the home market anyway, so they were really office workgroup printers.
