So the other day I had to babysit a final year engineering student for a few hours - can't solder.
It's not the lack at that stage of that skill alone that is a bit
per se, but everything that necessarily follows.
Another one a while back needed me to explain how to wire a switch to assert an I/O pin on one of those Ardeweeno things, or whatever they're called.
What would have Bob Pease or Jim Williams been without a soldering iron?
I started my professional career about ten years ago. Only engineers, I have witnessed soldering properly, were hobbyists or lab managers. I worked at Siemens R&D and now I am with TI in Germany. I had to buy even my own soldering tips, tweezers, wire cutters and fluxes because the Germans simply don't solder below 450°C (true for TI, true for Siemens) and tweezers look like tiger tanks in Soviet Russia in 1945. I've been to dozen labs all around the world and it was always the same story. Recently, a PhD colleague has asked me "hey, what is flux for?".
But hey, why to use a pre-heat station or change the tip for bigger, when you can kick the tiny 0.4mm weller tip to 450°C and fuck it up in an hour including the PCB?
9/10 EEs I've met had no idea about soldering, how it works, what flux does and why they should care. But I don't wonder anymore. My manager told me once "I did not hire you for soldering". I guess he hired me for powerpoints.
Bop Pease, Bob Widlar (my child heroes) would be just average engineers in today's corporations. HR would not tolerate Widlar's special personality and the communications department would not tolerate Pease's messy desk. There's no place for individualism today. Political correctness is more important. Just check Infineon's or Siemens's Linekdin profiles.
</rant> ; but feel better now
