I have the following EA-D20025PR-S Epson LCD.
It states that it is HD44780 equivalent using the SED178 controller so I guess the existing libraries for the HD44780 will do the job.
The pin arrangement is like:
The thing is that I can't find the datasheet in order to identify the I/O. The SED1278 isn't accessible (epoxy coated embedded ic) in order to use a multimeter continuity mode.
Does anyone ever used such an LCD? Any help on the datasheet?
Alexander.
