Author Topic: erase your flash just before detonation  (Read 866 times)
Offline ledtester
« on: September 19, 2019, 04:14:27 am »
From https://nypost.com/2019/09/18/irans-supreme-leader-approved-saudi-oil-attacks-report/
In addition to the satellite photos, circuit boards recovered from the wreckage of cruise missiles and drones can be reverse-engineered to reveal the weapons’ flight paths to the massive oil-processing plant in Abqaiq and oil fields in Khurais, CBS said.
Some thoughts/questions...
- Was flight data being stored in non-volatile memory?
- Is this claim true or a just a red-herring being used by US intelligence to throw off the Iranians?
- If the US was able to "reverse-engineer" the flight path did they really want that capability publicly disclosed?
Online BravoV
  • +++ ATH1
Re: erase your flash just before detonation
« Reply #1 on: September 19, 2019, 04:20:37 am »
Don't trust everything you read, and most of the times, as a hint, just follow the money's trail, like which country will have major advantages to fill in the gaping hole of oil disruption globally.
« Last Edit: September 19, 2019, 04:22:38 am by BravoV »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: September 19, 2019, 06:55:04 am »
So far, only the White House has been claiming Iran.  I wouldn't put much confidence in that unnamed "US official".
As for the technical plausibility, perhaps.  I don't know how much storage they need to operate those things.  If they took the cheap way out and put Linux on an SBC and patched in sensors and controls, it's quite possible; if it's a custom system (the more likely case, most militaries want something a bit more robust), who knows.  Flash is certainly used, but they might keep the particulars of targeting and flight planning in SRAM (or less likely, DRAM?), and this would be one motivation behind that.  Flash might still be used to hold terrain data, say; and if there's a limited amount available (so-and-so many megs, not gigs of storage), they might only load the local area, or at least at high resolution.  That could still be whole quadrangles of the world though, not real helpful at nailing down any particular base.
Looks like the wreckage is fairly intact, so even just desoldering the chips may prove fruitful.  Flash can be decapped and probed intact, if worse comes to worst.  Fractured chips aren't so useful though.
Seven Transistor Labs, LLC
Offline StillTrying
  • Country: Broken Britain
CML+  That took much longer than I thought it would.
