Hi all,
I've been having a disagreement with someone at work about whether or not some ESD floor matting needs attaching to a ground point, and was hoping some collective wisdom would shed some light one way or another.
- His view is that connecting to ground is not required as it is so big that it should dissipate constantly.
- My view is that BSEN 61340-5-1 clearly states that flooring system needs to be attached to the common ground point. I've never heard of the argument of large mats not requiring grounding.
Is there a case that can be made, that says that if the matting is large enough then a connection to ground is not required?
I could probably use a flash tester to measure the resistance, but we are all in lockdown so it's very difficult for me to perform any sort of testing.
Other notes: The matting is on painted concrete floor - the floor paint isn't anything special. However, I did conduct some burn-in breakdown tests elsewhere in the factory (so may have had a different floor paint) and noticed some arcing to the floor - so maybe there is something there? I can't remember what values I was running through, but it was arcing from black nylon wheels so must've been fairly high.
Any insight is greatly appreciated, thanks.
EDIT: This is in a production environment where the electronics are installed inside the product next to a row of benches. It is impractical to use to use wristbands, so we have implemented matting/floor paint and footwear.
