Author Topic: ESP8266 WiFi Rant.  (Read 20812 times)
Online Yansi
  • STM32, STM8, AVR, 8051
Re: ESP8266 WiFi Rant.
« Reply #50 on: April 13, 2015, 11:16:37 pm »
Bringing the measurements.  Unfortunately I forgot I've wanted  to measure also startup currents. The results look pretty interesting, I must say. Sometimes, the peak goes a bit over 300mA.
Also looks like the MCU sleeps and is periodically woken up.
Offline zapta
« Reply #51 on: April 21, 2015, 04:46:01 am »
The stock AT commands look good initially but when you get to the details they are hard to work with.
Correction, the ESP8266 AT commands work quit good. The trick is to disable echo ("ATE0", not documented) such that it doesn't interfere with "+IPD" RX data.
Drain the swamp.
