Author Topic: Please help identify Ohm value of the resistor  (Read 2191 times)
Offline zape
« on: September 29, 2017, 07:19:23 pm »
This one is from the Y-sus board of the samsung plasma tv
It is 5 bands but I'm not sure which band is the first
I suspect shorted zener diode (in a parralel) but it might be just low ohm resistor.
Offline metrologist
Re: Please help identify Ohm value of the resistor
« Reply #1 on: September 29, 2017, 07:45:19 pm »
red red gray black black?
If black is zero, I don't think they start with black. Maybe they do
Otherwise, I think there is a slightly larger gap on the last band. Or it starts closer to the edge.
« Last Edit: September 29, 2017, 07:48:19 pm by metrologist »
Offline madires
  • A qualified hobbyist ;)
« Reply #2 on: September 29, 2017, 07:46:26 pm »
AFAIK, there's no "black" tolerance. So the black band seems to be the first one, i.e. 018 * 10^2 = 1k8. And the red band indicates a tolerance of 2%. Still, a leading zero is unusual. I would expect brown grey black brown red.
Offline Benta
« Reply #3 on: September 29, 2017, 07:59:43 pm »
Looking at the E96 series, the only value that makes sense is 118 ohms (brown-brown-gray-black).
I hate these modern blue resistors. The colours used for coding are almost impossible to identify, as they seem to be partially opaque and the blue background comes through.
Offline MK14
« Reply #4 on: September 29, 2017, 08:06:25 pm »
Buffer IC's are bust, maybe ...
https://www.badcaps.net/forum/showthread.php?t=46761
I was going to suggest checking Vs-gnd on ymain. As far as repairing the Ymain, might be easier to find a working board since this has the buffer boards integrated.
There is a kit in the UK suggesting some clues what to look for
http://www.ebay.com.au/itm/LJ41-0590...item2ee14f8e40
and this comment, lease check R5085 / R5086, if there is a short across them then don't buy this kit as one or more of your buffer IC's have blown.
Offline zape
« Reply #5 on: September 30, 2017, 12:31:56 am »
After closer look I think the colors are:
black brown silver(gray) orange orange
here is the shot using better camera and no flash
« Last Edit: September 30, 2017, 12:42:01 am by zape »
Offline MK14
« Reply #6 on: September 30, 2017, 12:47:54 am »
"black brown silver(gray) orange orange"
I think it is Orange Orange Gray (338), Brown = x10 then Black for 250 PPM/deg K (PPM = Parts per million)
3380 Ohms with 250 PPM temperature tolerance per deg Kelvin (i.e. Black band).
Black band information source:
https://en.wikipedia.org/wiki/Electronic_color_code
« Last Edit: September 30, 2017, 12:50:46 am by MK14 »
Offline zape
« Reply #7 on: September 30, 2017, 02:27:15 pm »
I took the diode out and it was good.
Resistor measured fractions of Ohms. I have a bad multimiter so can not tell exact value. Chances are it is below 0.2 ohm
Eventually I get the TV working so I assume the Resistor is OK.
« Last Edit: September 30, 2017, 02:32:36 pm by zape »
Offline Monkeh
« Reply #8 on: September 30, 2017, 02:33:45 pm »
Resistor measured fractions of Ohms. I have a bad multimiter so can not tell exact value. Chances are it is even below 0.1 ohm
Orange orange silver brown = 0.33ohm.
Online Zero999
  • 0999
« Reply #9 on: September 30, 2017, 03:47:45 pm »
Yes, the black band on the bottom has a larger distance, than the orange bands, so it's the last band, not the first.
Offline MK14
« Reply #10 on: September 30, 2017, 09:50:53 pm »
I thought it was going to be a 5 band resistor, because it has 5 bands. But apparently, the last band (if Black), can just mean something else. See picture below:
I.e. I/we needed to treat it as a 4 band resistor + 1 band of Black to decode it.
Also, I think using both grey and silver as valid colour bands, is asking for trouble (mistakes).
Offline zape
« Reply #11 on: October 02, 2017, 02:02:34 pm »
I also noticed the second orange band is wider. Does this mean anything?
Offline Brumby
« Reply #12 on: October 02, 2017, 03:11:25 pm »
They used more paint.   ;)
No.  It means nothing.
Offline Andreas
« Reply #13 on: October 02, 2017, 04:36:30 pm »
In power supply cirquits it is often the marking for a "fusible resistor".
http://www.mouser.com/ds/2/427/pr02fs-1103091.pdf
with best regards
Andreas
The following users thanked this post: MK14, zape
Offline MK14
« Reply #14 on: October 02, 2017, 05:06:33 pm »
with best regards
Andreas
Thanks.
An additional
black color band is applied to differentiate the PR02-FS
from standard PR02 product.
I find the quoted bit, rather confusing. Because it means that there are 5 colour bands, yet only 4 of them count and the other (Black) one just changes the type of resistor. None of the online resistor guides I could find, seemed to know about this fact.
I guess there are a massive number of traps and things, within electronics. Which can easily catch you out, until you have experienced it.
So a Black band can mean, zero (0), be a multiplier, mean a specific PPM (similar to tolerance) amount and mean it's a fusible resistor. Possible other meaning as well.
No wonder I had such difficulty interpreting the colour bands.
Offline Brumby
« Reply #15 on: October 02, 2017, 05:43:53 pm »
I could read a 4 band resistor from 10 paces (well, not quite) .... but when these blasted 5 band blue-bodied creations began proliferating, I started keeping my meter handy to double check.
Online rdl
« Reply #16 on: October 02, 2017, 06:24:30 pm »
Yeah, the color bands worked okay until the fifth one became necessary. I gave up on them after that and just check with a meter. I think the paint used was cheapened also, making all the colors much darker and hard to tell apart.
Offline madires
« Reply #17 on: October 02, 2017, 06:54:55 pm »
There's always something to learn. I never would have guessed that a black ring could identify a fusible resistor.
Offline Andreas
« Reply #18 on: October 02, 2017, 07:46:32 pm »
Just to confuse you: other manufacturers use a white or violet ring for that.
https://www.vishay.com/docs/28737/nfr25.pdf
with best regards
Andreas
Offline Fungus
« Reply #19 on: October 03, 2017, 09:44:15 am »
I had a bunch of resistors where one of the bands completely changed color when they overheated. Something to do with the pigment in that particular paint. The color change was 100% perfect, no clue at all that the band used to be a different color until we got hold of a unit with non-failed resistors.
I don't remember exactly but it was something like red to yellow on the third band. Yes, replacing them caused a few problems.
Online Damianos
  • Country: gr
« Reply #20 on: October 04, 2017, 07:37:22 am »
The usual reading of the color markings are:
The first band is the nearest at the end of the component body.
The last band (if it is in same position as the first, to the other end) has a little more distance from the previous one.
When the resistor has pre-formed leads for vertical mounting, the first band is the top one. The resistor in the photo is this case, because the longer lead is insulated.
The color coding, of the bands next to the value, is sometimes very confusing; I have somewhere a few resistors of 10R and a few other bands (I don't remember how many!), that do not agree with any table. With the manufacturer unknown, to find a data-sheet, the meaning is a little dark!
