Author Topic: Explanation of HRC fuse prices?  (Read 4987 times)
Offline david77Topic starter
« on: November 24, 2011, 10:30:10 am »
Does anybody know what happened to HRC fuse prices? In particular the Littlefuse KLK series (10,3x38mm).
Recently prices for these fuses seem to have risen by about 5 times, Farnell used to sell them for 3,65 EUR a piece now they want more than 20,00 EUR! I've seen similar prices elsewhere, what's going on there?
Offline wkb
Re: Explanation of HRC fuse prices?
« Reply #1 on: November 25, 2011, 08:28:50 pm »
FWIW: I heared exactly the same thing here in the Netherlands when I inquired about a 440mA fuse for my Fluke.  Availability bad too.
So for now I have F0.5A in there.  I am not in the habit of short circuiting wall sockets with my Fluke set to current anyway.
The Fluke I got with the blown fuse inside.
Wilko
alm
  • Guest
« Reply #2 on: November 25, 2011, 10:03:29 pm »
I would stick a label on it declaring it only suitable for low energy circuits, and make it very clear that the CAT III/IV rating is not valid. You never know where it will end up. Having a device labeled something like CAT IV 600V, even though it will likely arc if a transient voltage occurs, is dangerous in my opinion.
Offline wkb
« Reply #3 on: November 25, 2011, 10:11:21 pm »
I get your drift, but no worries, this is my private meter and the only one using it is me.  My equipment is not being lent out.
Wilko
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« Reply #4 on: November 25, 2011, 10:16:27 pm »
If is that so, about the pricing, then I am an millionaire thanks to Fluke ?  ;D
https://www.eevblog.com/forum/index.php?topic=1307.msg27477#msg27477
Offline wkb
« Reply #5 on: November 25, 2011, 10:22:46 pm »
Well I was quoted EUR 13,25 for the 440mA fuse last wednesday.  And no stock :-/
Online kripton2035
« Reply #6 on: November 25, 2011, 10:51:55 pm »
it can be explained if the factory is located under the water in thailand ?
same happened for the hard drives recently...
Offline wkb
« Reply #7 on: November 25, 2011, 10:57:41 pm »
Could be the case of course.  The shop owner mentioned something about a manufacturer stopping production??
ENOCLUE...
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
« Reply #8 on: November 25, 2011, 11:05:32 pm »
There is always out there and SIBA about HRC fuses,  made In Germany !!  ;)
Alex
  • Guest
« Reply #9 on: November 25, 2011, 11:14:00 pm »
Could pretending to be a stupid user and contacting fluke to repair your DMM at their place work?
No?
Could pretending your Agilent DMM has never failed and contacting fluke to repair your DMM at their place work?
Hmmm  ;D
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
« Reply #10 on: November 25, 2011, 11:40:11 pm »
It did take me some time, so to translate the message of Alex ....  :P
Yes people, get some spare fuses !!  one pair of both it would help to worry less about it.  :)
Alex
  • Guest
« Reply #11 on: November 25, 2011, 11:47:29 pm »
You don't have to have access to an exceptionally intelligent translator, but I expect you to PM me if your translator gives you garbage! Since when the Greeks became shy?  ;D
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
« Reply #12 on: November 26, 2011, 04:28:54 pm »
No worries Alex ..  :)   It was easier than the Greek " iksis afikseis ouk en to polemo thnikseis "   ;)
