Nearly two years ago I bought a pack of 50 1500uF 10V "nichicon" branded caps at my local electronics store. I actually thought that caps were genuine nichicon ones, so I expected them to work quite well. I then used those caps in some of my projects, I made back then. One of those projects was a 320x240px color TFT screen, with a SSD1906 display controller and a AVR. It is powered by a 8-15V plug- pack. On the PCB the 3.3V and 5V rails are generated with standard 78** linear dropout regulators. On the output side of the 5V and the 3.3V regulator, I placed one of these caps for each output.
So far so good. Two years back the circuit worked fine with those caps. Since then, I never powered this circuit up again. Until today. I plugged in the plug pack and turned away from the PCB for just 4-5 seconds, until i heard a high pitch noise from a capacitor venting. I immediately disconnected the power and checked what was wrong. In the first moment I thought I accidentally used a plug pack with the false output polarity, but then I remembered that this wouldn't have been a problem because I designed in a diode for reverse polarity protection. So after a short time investigating the problem it was clear that the capacitors were the problem.
I then randomly picked one of the nearly 40 left over caps of that type out of my parts bin and connected 5V to them via my lab power supply. Instantly after I connected the leads the cap pulled nearly 2A
from the PSU and heated up quickly.
I then tested another 10 caps, all were absolutely dead. even at 3V they pulled 800mA. I'm a bit surprised, I've heard of fake caps having a very short life span, but I've actually never heard of caps being bad at the first time voltage is applied to them.
