Author Topic: How do you attach image?  (Read 1997 times)
Offline SgtRock
« on: October 13, 2011, 11:57:28 pm »
Greetings EEVBees"
--I am unable to attach an image to my post. I cannot find a description of how to do so in the help file. Could someone please tell where to read a description of this procedure. Thanx
"There are two possible outcomes: if the result confirms the hypothesis, then you've made a measurement. If the result is contrary to the hypothesis, then you've made a discovery." Enrico Fermi
Best Regards
Clear Ether
Offline westfw
Re: How do you attach image?
« Reply #1 on: October 14, 2011, 09:06:14 am »
There was an image attached to your post...
Offline amspire
« Reply #2 on: October 14, 2011, 09:59:39 am »
Greetings EEVBees"
You got half way there. You attach an image and then you post it - as you did.
After it is posted, right click on the link to the image in the new post and copy the link to clipboard.
Then modify the post, add an image link (button under the "B") and paste the link URL in. Save the post.
The alternate way is to host the link elsewhere so you can put the link straight in. No need to modify your posts, but if in the future the external link dies, then the post will no longer be much use to anyone.
Richard.
