Author Topic: Software for generating waveforms.  (Read 1667 times)
Offline firewalkerTopic starter
  • Country: gr
« on: February 24, 2017, 02:52:29 pm »
Is there an software for creating waveforms in order to be used in a manual etc?
Most of the time I use LtSpice with arbitrary voltage sources etc.  But for waveforms like the one bellow...
Alexander.
Offline Vtile
  • Ingineer
Re: Software for generating waveforms.
« Reply #1 on: February 24, 2017, 03:39:51 pm »
Any math program should do? Matlab, Maxima, Maple ... Excel, OpenOffice Calc, GnuPlot what there is these. What they expect as a input data is what rules some of them out.
Your waveform in question is a variation of f(x)=tan(x)
..Or are you asking a program that allows you to draw by hand the waveform.
« Last Edit: February 24, 2017, 03:46:33 pm by Vtile »
The following users thanked this post: firewalker
Offline Ampera
    • Ampera's Forums
« Reply #2 on: February 24, 2017, 03:51:32 pm »
Google! Just input your waveform you want to graph, and it will do it. Seriously.
https://support.google.com/websearch/answer/3284611?hl=en#plotting
I forget who I am sometimes, but then I remember that it's probably not worth remembering.
EEVBlog IRC Admin - Join us on irc.austnet.org #eevblog
Offline rstofer
« Reply #3 on: February 25, 2017, 05:10:23 pm »
I use desmos.com for graphing but I haven't had success at saving a simple image.  I can save the entire .html but that is pretty much useless.
You can certainly do the same thing with wxMaxima and there are a couple of graphing formats.  The first attached image uses the 'inline' format.  The second image uses the gnuplot format and it is a separate window.  Both approaches have a lot of options for sizing, legends, labels and so forth.
Offline shteii01
« Reply #4 on: February 26, 2017, 01:23:11 am »
Hit Print Screen (if you have multiple windows open, hit ALT+Print Screen to capture active window), then Paste to your favorite graphics editing program (and no, I don't mean stupid M$ Paint), edit the pic, save the pic.
I recommend IrFanView graphics editing program.  If you need fancy, White Rabbit version for Photoshop might still float around the internetz.
