Author Topic: Update on the NASA Voyagers  (Read 1580 times)
Offline BentaTopic starter
The following users thanked this post: Gyro, RJSV
Offline mendip_discovery
Re: Update on the NASA Voyagers
« Reply #1 on: October 24, 2023, 08:27:31 pm »
I wish they would send more like this out there. With what we know we might be able to improve their abilities and maybe get them further out. Or at least get a snapshot of the same data but 50 year apart.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
Offline Messtechniker
« Reply #2 on: October 24, 2023, 08:33:03 pm »
Just wondering what sort of
capactors are being used here.
Built during pre-capacitor plague eara :)
Probably the circuits use as few capacitors as possible.
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter
The following users thanked this post: Ed.Kloonk, magic
Offline Gyro
« Reply #3 on: October 24, 2023, 08:46:10 pm »
Any capacitors of significant size are probably Wet Tantalum.
Best Regards, Chris
Offline Gyro
« Reply #4 on: October 24, 2023, 08:53:43 pm »
I seem to remember some controversy about the safety risks of launching Radioisotope powered SVs. I can't find much on the NASA website in the way of recent launches - although most other stuff can be done with solar panels.
Best Regards, Chris
Offline TimFox
« Reply #5 on: October 24, 2023, 09:08:37 pm »
There is indeed controversy surrounding the plutonium-pile powered spacecraft, which use a thermopile (battery of thermocouples) stuck into the reactor to generate electrical power.
The main contention was possible problems if the spacecraft failed during launch, before leaving the Earth.
See  https://rps.nasa.gov/technology/  for NASA's description.
« Reply #6 on: October 24, 2023, 09:36:44 pm »
"Reactor" is a bit over the top to my mind. It evokes images of "China Syndrome" etc.
It's simply a lump of 238Pu with thermogenerators stuck to it.
Apart from the fact of Pu being somewhat poisonous, I don't see a radiation issue.
« Last Edit: October 24, 2023, 09:46:34 pm by Benta »
« Reply #7 on: October 24, 2023, 09:45:25 pm »
So do I. But the Voyager missions were based on a special planet constellation that enabled "slingshot" acceleration by passing close by two/three of the big planets.
Back then, it was a breathtaking race to get them launched to take advantage of that. So they were built "quick-n-dirty" and still survive.
Something to think about.
Offline TimFox
« Reply #8 on: October 24, 2023, 10:02:43 pm »
To get heat from plutonium, you need to assemble enough to create a chain reaction.
This is usually called a "pile" or a "reactor".
Plutonium, in fact, is poisonous, like other heavy metals, but its radiation is not a big problem if you don't ingest it.
Offline rdl
« Reply #9 on: October 24, 2023, 11:39:00 pm »
RTGs use the heat from normal radioactive decay of plutonium. No chain reaction is involved.
Offline TimFox
« Reply #10 on: October 24, 2023, 11:49:03 pm »
Yes, that's true of the RTG as discussed in the NASA article.
Actual fission reactors have been used in spacecraft by the Soviet Union, and once by the US for higher power in spacecraft.
See a discussion in  https://world-nuclear.org/information-library/non-power-nuclear-applications/transport/nuclear-reactors-for-space.aspx
Possible electrical generators discussed include thermopiles and Sterling heat engines.
Online Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #11 on: October 24, 2023, 11:59:16 pm »
For me (as a certified tapehead) the most interesting fact is that Voyager 2 has a (still operational AFAIK) tape recorder on board.
 8)
Cheers
Alex
Offline Psi
« Reply #12 on: October 25, 2023, 12:30:15 am »
The issue, I think, was a mission failure where the craft re-enters the atmosphere and burns up. You don't want to spread a mist of Pu238 over a wide area.
I seem to recall the radioactive material is somewhat shielded in a way to survive reentry intact. But there is always a risk, it could get hit with other space debris and shattered into small pieces before re-entering.
But if we want to explore the outer solar system it's really the best option.
« Last Edit: October 25, 2023, 12:32:56 am by Psi »
Offline Andy Chee
« Reply #13 on: October 25, 2023, 05:05:53 am »
Fission reactors were probably deemed too unreliable for deep space probes (too many moving parts for control rods) as retrieving the satellite for repair is not an option, hence the preference for RTGs (zero moving parts).
Uranus and/or Neptune are priority targets for NASA for an orbiter probe, similar to Cassini & Saturn, so watch this space.  Any launch trajectory will inevitably require gravity slingshots, probably from Venus and/or Earth.
« Last Edit: October 25, 2023, 05:07:48 am by Andy Chee »
Offline FrankBuss
    • Frank Buss
« Reply #14 on: January 01, 2024, 11:27:17 am »
I wonder if there are details about the computer on the Voyager and the software, or even an emulator. I just found some general descriptions, like that they are using 3 computers, and Fortran and assembler. I guess NASA has an emulator for it? Would be fun to play with.
Offline schmitt trigger
  • Country: mx
« Reply #15 on: January 01, 2024, 05:07:01 pm »
Weren’t these the probes fitted with COSMAC processors?
Offline FrankBuss
    • Frank Buss
« Reply #16 on: January 01, 2024, 05:19:25 pm »
No, looks like this is a misconception, according to this site: https://www.retrotechnology.com/memship/1802_spacecraft.html
It also notes that UDS was previously implemented in Voyager - on CMOS but discrete hardware, not on microprocessors.
