Author Topic: Firefox issue with viewing this forum  (Read 5916 times)
Offline David_AVD
« on: November 14, 2012, 10:31:31 pm »
Starting this week, every time I visit any page on this forum, the following dialog pops up twice. I click cancel each time.
It has to do with the advertiser "supplyframe.com" but not sure why this suddenly started.  I don't get this effect in IE on the same machine, or FF on another (XP) machine.
Any ideas?
Offline McMonster
    • McMonster's blog
Re: Firefox issue with viewing this forum
« Reply #1 on: November 14, 2012, 10:49:40 pm »
You can try clearing the browser cache (Ctrl+Shift+Delete) and/or installing AdBlock (you can just block the ad's domain if you want).
Offline Sionyn
« Reply #2 on: November 14, 2012, 10:56:59 pm »
this might be a click to play added in firefox
eecs guy
Offline David_AVD
« Reply #3 on: November 15, 2012, 12:16:36 am »
AdblockPlus is already installed.  Cookies and cache cleared with no improvement.
Offline iloveelectronics
  • Country: hk
« Reply #4 on: November 15, 2012, 12:40:58 am »
Looks like you have installed some adware/spyware type of stuff. Go under the Tools->Add-ons menu and uninstall any suspicious addons or plugins.
My email address: franky @ 99centHobbies . com
My eBay store: http://stores.ebay.com/99centhobbies
Online andersm
« Reply #5 on: November 15, 2012, 01:14:05 am »
SupplyFrame seems to be Dave's ad provider, I'm guessing it's just a transient glitch on their part.
Offline r90s
« Reply #6 on: November 15, 2012, 06:36:20 am »
I don't think his computer has a bug. I think his firefox is blocking part of the SupplyFrame widget and misinterpreting whats going on and trying to download one of the widgets frames, judging by the file size.  Possibly his adblock is acting up..
Whack those electrons 8)
Offline Psi
« Reply #7 on: November 15, 2012, 07:56:49 am »
I use firefox with no adblocker and I've never seen that happen on eevblog.
Offline David_AVD
« Reply #8 on: November 15, 2012, 09:05:15 am »
Same result with AdBlock+ on or off.  Was working perfectly until last Monday.  Works fine at home on an XP PC.  I'll just not visit the forum from work I guess.
Offline McMonster
    • McMonster's blog
« Reply #9 on: November 15, 2012, 09:58:33 am »
That changes a bit, might be employee's cache server issue. Does it happen on other computers at work?
Offline EEVblog
« Reply #10 on: November 15, 2012, 09:59:33 am »
Sorry, no idea. No other reports of issues, and I don't see it myself.
Dave.
Offline David_AVD
« Reply #11 on: November 15, 2012, 10:53:57 am »
I have another identical machine on my work bench, so will try it there next week.
Offline Psi
« Reply #12 on: November 15, 2012, 10:56:48 am »
Try rename your firefox profile (so it creates a new one) and see if the problem goes away.
You can always rename it back again.
Offline Jacob
« Reply #13 on: November 16, 2012, 04:58:16 pm »
Yeah dude i have also facing same problem that this forum is not open in the Firefox i think its browser problem and i open this forum to chorom it is easily open it..change the browser and then try it...
Offline Neilm
« Reply #14 on: November 16, 2012, 05:05:51 pm »
I'm using FireFox and have had no problem (yet).
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline David_AVD
« Reply #15 on: November 17, 2012, 02:06:35 am »
Just to reiterate:
I'll try FF on the other Win7-64 machine at work on Monday.
Offline HackedFridgeMagnet
« Reply #16 on: November 17, 2012, 05:25:47 am »
I use firefox and it renders ok for me.
That link is within an Iframe tag. not sure if this is the issue.
Try this link in firefox by itself.
http://search.supplyframe.com/partner/26/ipo950/
the other thing you can do is reset firefox.
just remember what plugins you want to re install then go help->trouble shooting information.
there is a button here that says reset. It could help.
Offline jancumps
  • New Low
« Reply #17 on: November 17, 2012, 06:56:04 am »
Happened to me too at the same time, with Safari. I got the exact same message. Clearing cache didn't help. It was gone the next morning.
Offline ModemHead
  • No user-serviceable parts inside.
    • Mr. ModemHead
« Reply #18 on: November 17, 2012, 02:00:48 pm »
Your Firefox seems to be confused about the mimeType application/x-httpd-php. Looking through a debugger, I can't see any responses from search.supplyframe.com that contain that mimeType.  So I have no explanation, but here's a shot in the dark: delete or rename the mimeTypes.rdf file in your Firefox profile.  Firefox will rebuild it when re-started.
alm
  • Guest
« Reply #19 on: November 17, 2012, 02:29:40 pm »
I've seen this happening once or twice. Went away after a while. My guess is that it was a intermittent issue with the ad provider.
« Last Edit: November 17, 2012, 04:17:30 pm by alm »
Online PA0PBZ
« Reply #20 on: November 17, 2012, 03:14:44 pm »
Got the same with IE9, both at home and at work. I assumed it would go away and it did  8)
Offline George_Race
    • Race Consulting
« Reply #21 on: November 18, 2012, 12:58:53 pm »
This may not be the solution you are looking for, but is something you should run on your system from time to time to just keep it clean running and fast.
Download and run the program "HijackThis"
Start the program, select system scan.  You will have a list of all the stuff that is currently being loaded and running on your system.
Mark and remove any lines that have references to either or both, FireFox and SupplyScan.  Restart your system and the problem you are having will probably be gone.
If you run HijackThis and have more than about 5 or 6 items listed, you have things running that don't need to be there and are slowing down your system.
This is really a great tool that I have used for years.  Take time to learn how to use HijackThis, it has lots of information about it's use, and is a safe program to run.
Hope this helps,
George
Offline David_AVD
« Reply #22 on: November 18, 2012, 10:06:12 pm »
Well, who really knows what was causing this as today (1 week later) the issue has resolved itself with no further intervention.   :P
