Author Topic: Firmware Flash Retention  (Read 773 times)
Offline msuffidyTopic starter
« on: November 11, 2023, 03:50:47 am »
If your firmware or BIOS is on flash, does the data risk eventually draining out to the discharge state?
Is NOR better than NAND regarding this?
Is there any difference between EEPROM and flash?
Offline CountChocula
  • I break things—sometimes on purpose.
Re: Firmware Flash Retention
« Reply #1 on: November 11, 2023, 07:02:15 pm »
Eventually, data on a Flash chip might be lost, depending on a number of factors, including the number of write/erase cycles the memory has been subject to. I think (but not 100% sure) that NOR has better retention than NAND, in that it's less susceptible to random bit flips. Manufacturers usually specify data retention in their datasheets (typically 10 years or longer for most modern parts).
Flash is a descendant of EEPROMs… for more information, Google is your friend :).
Lab is where your DMM is.
Online Siwastaja
« Reply #2 on: November 12, 2023, 12:27:15 pm »
Of course, and data retention lifetime is one of the key parameters to the point of being sometimes mentioned on the very first front page of a microcontroller.
