Author Topic: First of the 25 posts on page  (Read 1426 times)
Offline StillTryingTopic starter
  • Country: Broken Britain
« on: August 31, 2018, 07:49:19 pm »
I tend to remember the first post of the 25 on a page, especially if it's an image, or a reply from or to me.
Anyone noticed that the first post on a page sometimes changes to another post, or is it just me(going nuts).
As an example, I think this one used to be the first on a page, and now it's not, or is it some post deletions or something.
www.eevblog.com/forum/projects/the-ubeam-faq/msg1713416/#msg1713416
« Last Edit: August 31, 2018, 07:52:23 pm by StillTrying »
Offline Muttley Snickers
  • Cursed: 679 times
Re: First of the 25 posts on page
« Reply #1 on: September 01, 2018, 12:37:45 am »
It generally means somebody has deleted posts prior to yours, if you made a post at say #100 in a thread and someone later removed two prior posts then your one would become #98, this will in turn place your post at a different location on that page or even on a prior page.
« Reply #2 on: September 01, 2018, 02:07:35 am »
Delete 1st post test. >:D
Edit: As expected you can't delete the 1st post of a thread.
An Error Has Occurred!
You cannot delete your own topics in this board. Check to make sure this topic wasn't just moved to another board.
« Last Edit: September 01, 2018, 02:11:05 am by StillTrying »
Offline Brumby
« Reply #3 on: September 01, 2018, 05:35:27 am »
No, you cannot delete the first post of a thread, but you can delete any of your own posts after that.
Offline Brumby
« Reply #4 on: September 01, 2018, 05:37:10 am »
For example:  Here is a post I will delete in a minute or so.......
Here I am quoting it, so you can see it existed.
Offline Brumby
« Reply #5 on: September 01, 2018, 05:37:54 am »
Now I have I deleted it.
« Reply #6 on: September 01, 2018, 12:30:25 pm »
I almost expect a deletion or 2 in a current thread, but I'm surprised when the deletion(s) from the previous page(s) must be of posts which are weeks/months old.
I think you can delete the 1st subject post as long as there are zero replies to it, because I seem to remember on at least one occasion I've posted a question, and them changed my mind and removed it, of course I might just be imagining it.
Another useless snippet. The message numbers ( #msg1790588 ),  increment over 10 times faster than the total number of visible posts.
« Last Edit: September 01, 2018, 12:32:26 pm by StillTrying »
