Author Topic: C51 4 Bits Electronic Clock kit  (Read 10170 times)
Offline ledtester
Re: C51 4 Bits Electronic Clock kit
« Reply #25 on: January 11, 2021, 08:44:46 pm »
I came across an Arduino based programmer for the 2051:
https://github.com/piotrb5e3/AT89C2051_programmer
Also, the attiny2313/4313 is pin-compatible with the 2051, so you could replace it with an AVR-based mcu.
Offline aldolo
« Reply #26 on: January 12, 2021, 09:13:32 am »
Hi Edy. I've found posts stating that the shipped chip was not programmed at all. Unfortunatly the chip is usually the "parallel" and not the "serial" version so the programmer is a little bit costly. i'm checking the ledtester link. it could be a nice pasttime. what a pity that this clock are not sold at 1$ anymore.
« Last Edit: January 12, 2021, 09:17:01 am by aldolo »
