Author Topic: Fixing Leaking Electric Kettle  (Read 1901 times)
Offline Boris_yoTopic starter
  • Country: il
« on: December 01, 2021, 06:07:38 am »
Hello,
Disassembled kettle's base and want to locate the leak. By itself it does not leak. It leaks only when I lift and shake it and sometimes when I tilt it. Also, what kind of material is used to fill crevices/slits?
Thanks
« Last Edit: December 01, 2021, 06:13:47 am by Boris_yo »
Offline bob91343
Re: Fixing Leaking Electric Kettle
« Reply #1 on: December 01, 2021, 06:22:58 am »
I have never been successful at stopping electric kettles from leaking.  Just buy a new one.
Offline james_s
« Reply #2 on: December 01, 2021, 08:07:19 am »
That looks like a lot of corrosion, does that particular kettle have sentimental value or something? You might be able to patch a leak with some high temperature epoxy depending on where it is, but I don't think I'd count on it to hold up over time.
Online Gyro
« Reply #3 on: December 01, 2021, 09:15:10 am »
That just looks like an ageing kettle to me. As part of the boil cutoff mechanism, some steam / condensation makes its way into the internals (and maybe a tiny amount of seepage). This is normally prevented from building up by a drip hole in the bottom, but the environment is very humid. Shaking and tilting probably causes some condensate to drain.
If the kettle isn't causing an earth leakage trip, then it isn't bridging the insulation gaps that are deliberately designed for the conditions. Carefully avoiding overfilling is about the only way of reducing moisture in the base.
If dripping becomes excessive, or operation fails (burnt out contacts or broken bimetal click spring), there is no real alternative to replacing it.
Best Regards, Chris
Offline Miyuki
  • Country: cz
    • Me on youtube
« Reply #4 on: December 01, 2021, 09:57:18 am »
Thermal cycling fatigue cracks have no fixing
The only way is to recycle the material, melt it and make a new kettle
It just turns to a brittle spongeous mess
Online wraper
  • Country: lv
« Reply #5 on: December 01, 2021, 10:07:42 am »
There must be a rubber seal around the heating base which leaks. To fix it long term you will need to replace it and clean all of the calcium build-up underneath it. If you just clean it and leave the old seal, kettle will start leaking again after a few months.
Online Gyro
« Reply #6 on: December 01, 2021, 11:39:56 am »
I suspect that these days, it's a one time crimp seal around the rubbler. I've never had any success getting one apart to that level.
Best Regards, Chris
Online wraper
  • Country: lv
« Reply #7 on: December 01, 2021, 11:53:50 am »
There is a round plastic part around the edge which holds the heater in place, IMHO looks removable.
  • Country: il
« Reply #8 on: December 02, 2021, 02:46:14 am »
You mean that dripping is supposed to turn off kettle and redirect voltage to ground by tripping residual-current device?
What if leakage is not actually a leakage but accumulation of a condensation caused by escaping steam from within like someone pointed out?
Online Kleinstein
« Reply #9 on: December 02, 2021, 11:50:07 am »
The normal turn off is not from the dripping water conducting current. This would be a possible failure mode to than trip the GFI.
The normal turn off is from steam condensing and this way heat a thermal sensor (bi-metal) to switch off. Without water is in kettle, the higher temperature and normal heat conduction should make it turn off too.
It does not need much condensed water to heat up the sensor enough, but it would be some. This water needs to flow off somehow and may leak out.
