Author Topic: Flaky eBay buck converter  (Read 2735 times)
Offline netdudeukTopic starter
« on: June 21, 2015, 06:00:52 pm »
Ok, so I bought one of these http://www.ebay.co.uk/itm/351020297464
I wasn't expecting to be able to push it to the specified limits but it didn't even pass any tests.
Hooking it up to my DP832 with a multimeter on the board's output, the output voltage always started just below the input voltage and went on to rise to a higher voltage.  For example, 15v in produces 16v out.  According to the DP832, only 13mA was drawn in this example.
Adjusting the pot made no difference at any time.
No heat generated at all.
I know that this is a cheap board so it's not about the money but I would be interested from a learning perspective if anyone has any ideas about what's been going off with it.
Can these and similar boards ever be trusted ?
Offline dexters_lab
Re: Flaky eBay buck converter
« Reply #1 on: June 21, 2015, 06:29:29 pm »
likely  just a faulty one. Email the seller they will probably just send you another
Offline rolycat
« Reply #2 on: June 21, 2015, 06:35:18 pm »
It's unusual for the output voltage to be higher than the input, but have you read this thread?
You need to turn the trim pot anticlockwise a lot.
Offline tom66
« Reply #3 on: June 21, 2015, 06:46:52 pm »
I wouldn't be surprised if the internal switching transistor is shorted.
Offline electr_peter
  • Country: lt
« Reply #4 on: June 21, 2015, 08:42:53 pm »
Turn the pot (it is misleading at first) and do more tests with various input/output voltages and load currents. There is not much that can fail in listed DC/DC converter.
Offline con-f-use
  • Country: at
« Reply #5 on: June 21, 2015, 08:57:16 pm »
The exact same module is sold almost everywhere in china. It functions reasonably well. I'd say, you either have a shorted leg or something is wrong with the trim pot or yours is faulty.
« Reply #6 on: June 21, 2015, 09:15:34 pm »
Thanks for the replies including the reference to the previous thread.  Rolycat got it right
