Author Topic: Flood Light for Stair in the Garden?  (Read 883 times)
Offline Lord of nothingTopic starter
  • Country: at
« on: October 16, 2017, 09:57:59 am »
Hi
I know there are a lot of Products out there and many of then are Relabel China Crap.
Can someone recommend an Flood Light for the Garden who can switched off/ on by an Relay?
The Building is 4 Floors hight where the Lamp should mounted on and the footpath is along the Side of the House.
That mean I need an Beam who goes more an rectangle shape. The Flowers dont need to get light up in the night.
I got an Axis IP Cam (with an Training) who should mount next to the Light and when the Cam detect some moment the light should switch on. The Cam have 2 Ports for output who can switch an Relay.
We have here 230V.
Is a Relay required or are any other way to cut the power off to save money?
Thanks!
Made in Japan, destroyed in Sulz im Wienerwald.
Offline cdev
Re: Flood Light for Stair in the Garden?
« Reply #1 on: October 16, 2017, 01:22:46 pm »
You definitely need a relay and typically it is controlled by a low voltage output from your alarm system. Simply connecting the alarm signal to an appropriate type of relay works (the ways they work vary by manufacturer and setting, it should be laid out in the documentation for the alarm-connected device- so you need to give us more information)
Opto isolation is good to have if there is a chance of lightning hitting nearby trees. In a world of long wires and lightning, given how cheap a relay board with opto protection is now, why not, it should be opto-protected.
I have an alarm - a real alarm system.. so at the time it was being installed, I used a very sensitive relay board from Elk specifically for alarms, which was kind of expensive but I now realize that a great many other relay boards would have worked just as well and have been much cheaper (and they also provide opto-isolation from high voltages going in either direction- useful if there is an almost direct lightning hit.)
As far as flood lights you only need to get a generic light that shines in two directions. An adjustable light with two separate floodlights. Typically they mount to a wall in the middle and can shine both ways.
Watch out for false alarms- be considerate of others sleep.
If it would bother neighbors, better for your light to only go on if somebody is right there than go off every time deer walk by, etc.
« Last Edit: October 16, 2017, 02:10:59 pm by cdev »
