I'm posting this in some of the other Electronics places on the net as well...
I live in Ipswich, Queensland, Australia, thankfully on high ground. Very soon the flood cleanup will begin and some friends and strangers will be re-entering their homes and starting the process of cleaning and dumping.
I'm pretty keen about (safely) re-using rather than dumping but in this situation it can only go so far and there is a line drawn (often at dumping everything) about what can be saved. In the past I have successfully saved CRT TVs, Amps and other gear subjected to flooding by stripping, thoroughly cleaning with fresh water and drying completely (sometimes aided by de-watering fluid).
The trick is to get the gear early, before the mud and contaminants start the corrosion process.
Question is... what gear is not even worth attempting? Is it a complete waste of time with the low construction quality of most electronics today.
I'm already considering flat panel TVs in this group, along with portable devices that are battery powered.
How do hard drives survive 48 hours of inundation?
Any constructive input would be appreciated.
Thanks.
