Hi, I am new here, I tried doing a search on this, but did not have much luck
Long story short, I just bought a "lightly used" Fluke 117 off ebay, that I now question just how true that statement is, my purpose in buying it was as a grab and go basic reliable meter, mostly for general electrical / industrial equipment use. Note I have a few other Fluke meters, 87-V, 337a clamp meter, and 1507 insulation test meter.
I only had limited time to inspect the meter before I was called away due to an emergency, and in my rush left the meter at work, however in that time I did notice a few things:
Meter appears lightly used, and is in mostly good shape, but was not good enough for the "used only once" description the seller gave
Both probe tips were covered in unknown black charcoal looking material, continuity test would not work, may have been something burned on from an arc flash, rubber had no marks, I cleaned the tips with some industrial degreaser they now appear like nearly new, and continuity test works, however meter reads about 5.7 ohms when tips are in good contact with each other. I was just getting to retest with a second pair of fluke leads when I was called away, these also seem to read in the same 5.something range.
I have not had a chance to test any of its other features, but assuming they work, my plan is to adjust its calibration against my other Fluke meters, none of which have current calibration, but tend to agree closely with each other. My concern here is the black charred looking probes and 5.7 ohms being way outside of expected error for this meter. What do you think, should I send this one in for Fluke repair and expect to pay through the nose, just live with it, etc?
thanks
