Author Topic: Fluke 164 Counter Demo Aid  (Read 1620 times)
Offline sambonatorTopic starter
« on: May 02, 2019, 12:37:04 am »
I found an interesting 1979 relic from Fluke.
From what I gather from the markings, it appears to be a signal generator for frequency counter product demonstrations.
It can be AC powered or powered by its internal 4 D cell NiCD batteries.
It just takes unscrewing 1 screw to slide the entire unit out of the case.  Accepts 115V or 230V via switch on the board.
Sorry about the poor smartphone pics!
The following users thanked this post: lowimpedance, grbk
Re: Fluke 164 Counter Demo Aid
« Reply #1 on: May 02, 2019, 12:43:34 am »
Here are the internals.
The 4 NiCd D cells have shrink wrap around them, along with cardboard protectors to protect the board from battery leakage.
« Reply #2 on: May 02, 2019, 12:52:19 am »
Non-custom IC's, standard GE NiCD D Cells.  Looks good for 40+ yrs old.
« Reply #3 on: May 02, 2019, 12:54:30 am »
Cool thing is, it still works, as a Fluke should  ;D
« Reply #4 on: May 02, 2019, 12:57:59 am »
Scope readings, from left to right BNCs, going through each setting.  The knobs were set to top dead center.
(sorry I'm still a scope noob)
« Reply #5 on: May 02, 2019, 01:01:16 am »
Last 4 scope readings.  Hope you enjoyed! :)
Only thing that didn't make sense to me is the DC setting (DC 5V 10KOhm... what is that for?).
« Last Edit: May 02, 2019, 01:09:40 am by sambonator »
Offline lowimpedance
  • Watts in an ohm?
« Reply #6 on: May 02, 2019, 03:34:35 am »
Interesting unit , built into the same housing used for their 8000 series DMM's and the 1900a counters. Same nicad battery layout as well.
Relic indeed, thanks for posting
« Reply #7 on: May 08, 2019, 10:00:12 am »
I'm going to put this on the bay... I don't have room for collecting vintage equipment, and I had fun with this already, so time to pass it on  :)
I need to do that with my HP 3455A too.
Got it "parts or not working" and "untested" so I expected to do some learning and repair... but seems to be spot on in all measurements and quite stable, so I don't want to mess it up!
Online tooki
« Reply #8 on: August 19, 2022, 05:02:17 pm »
A Fluke 164 counter just came up for sale on the local auction site, so I suspect that the object above is the demo aid for the 164, rather than being named “164” itself. Given that the 164 counter is 20 years younger than 1979, I bet they just found an old generator in a closet and gave it custom labeling because… reasons.
The 164 looks like an interesting critter, in that it’s in a ScopeMeter housing and has some interesting scope-like features, and a really odd sampling mode where it samples at various voltage thresholds, rather than by time. See the attached datasheet.
« Last Edit: August 19, 2022, 05:05:01 pm by tooki »
