Author Topic: Fluke 87V displaying "Lead" and sounding beeper when nothing is plugged in  (Read 12983 times)
Offline king.osloTopic starter
  • Country: no
Hello there,
I've got a Fluke 87V.
Today, when I came to switch it on, it began sounding an alarm and display "lead" when I switched it on, despite nothing being plugged into the jacks.
When it turn it to mA or uA, it shuts up.
Is this a common problem? What should I check?
Thank you for your time.
Kind regards,
Marius
Offline NiHaoMike
    • Facebook Page
Use compressed air to blow out any dust.
  • Country: no
That worked.
Is there optical sensing of the input jack?
Kind regards,
Marius
Offline NiHaoMike
    • Facebook Page
If you take a look at the teardown of the 28 II, yes, it's optical.
  • Country: no
Thanks!
Kind regards,
Marius
alm
  • Guest
The 28-II may be optical because it's easier to seal, but many other meters (which I believe includes the 87V) measure resistance between two halves of the banana jack. I would clean the jacks with either compressed air or a Q-tip with isopropanol.
Offline Louis_C
  • Virtual lobotomies are now REAL!
    • Hamvoip RF/IP UHF repeater system
There is also one other thing to look at when you have a unit with this issue. After taking the unit apart have the board face you like normal. To the right and just above the (+) input terminal is a white ceramic resistor network. Make sure you have NO cold solder joints on the resistor pins or on the board. THAT will fix your issue. Good luck! Lou.  :-+
I reject your reality and insert my own hyper-dimensional space. Made with real artificial ingredients.
