Kjelt, There's a similar Saturn rocket here in Huntsville , Alabama. When I take people on a tour, I always make sure i show them the SMALL things that combine to make the huge rocket. Every one of those brackets, welds, rivets, data cables --- all the parts that go together --- were engineered in detail, machined, cut, soldered, installed and tested --- basically hand-built by real persons. It's easy to get blown away by the sheer size and power of the thing; but you will truly understand the effort that went into it only if you revert to the macro view; then it's breathtaking.
I got to spend lots of time climbing around on it while we were getting ready to static-fire the first booster. That was decades ago, but it's still fresh in my mind!
