I had a read through the e-cat report and there are some highly questionable methods.
Why would you use an AC heater and triac controller when DC would be far easier to measure accurately without any doubt over issues like power factor.
It's not a triac controller. Observe the interestingly square pulse waveforms shown.Edit: Hmm. looking at it again I don't know
what those waveforms are. Stupid little obscure display. Are they total power envelope? What timescale? How come 'up' and 'down' pulses? Don't even know what the units are.
Some scope captures of the actual drive signals would have been nice.
I found this aspect very interesting. There are three 'phases' of heater coils, and yet it _isn't_ using the obviously simplest form of heater control - triacs, with either zero crossing cycle on/off pulsing or phase control.
Why?
Also, why three separate heaters and not just one?
Given that there's clearly some unconventional physics going on (unless the supposedly independent reviewers are flat out lying about the isotope ratio shifts, or they had a trick pulled on them, and my gut feeling is they are not lying and weren't tricked), perhaps those odd aspects of the drive system are fundamental to the process? I'd be inclined to expect that simply heating a sample of the same fuel material up to that temperature, with a flame, or simple electric heater, won't achieve anything.
There's also the aspect that whatever the process was, the signals applied via the heating coils were apparently exerting a control influence, beyond simple temperature control. Lots of excess power output, but it didn't run away? Interesting.
So when you say "highly questionable methods" I think you are confusing the machine, and the methods chosen by the investigation team to examine it. They're given the machine and can't change how it operates, or there'd be no point. They have to choose methods suitable for the constraints imposed by the nature of the device as provided to them.
Why would you attempt to measure the output with a thermal imaging camera when you could just wind a water coil at a suitable distance to maintain the required temperature and measure actual heat output with a much higher degree of confidence.
A full calorimetry setup would be quite difficult for something like that. Since the device has to run at around 1000 deg C, you'd have to have a fairly large enclosure with heat exchangers some distance from the device. Which makes insulation, feed-throughs, and visual observation of the device difficult. It would also be expensive, and take time to set up.
If this thing was real it would be very easy to set up a demo that was completely convincing and couldn't be realistically challenged. Yet once again we see unnecessarily convoluted test methods and secrecy, giving rise to a strong smell of bullshit.
As someone on Slashdot commented, these things should be evaluated not only by scientists, who come at things with a narrow mindset and aren't used to being tricked or misled , but also by people experienced in spotting fraud, trickery and misdirection, like magicians.
I'd like to know whether Rossi or any of his associates were present during the tests the report discusses. I got the impression he wasn't, but I don't recall them specifically saying he wasn't. Need to re-read it with that question in mind. He's mentioned, but was it just phone conversations, etc, or was he ever in the room?
