Author Topic: Free App To Recovber Files From Sd Cards  (Read 2473 times)
Offline nvidiaTopic starter
« on: October 20, 2018, 01:30:32 am »
hey guys found some of my old sd card and wanted to recover some files off them I may have deleted
any free program out there I could use?
Offline Halcyon
  • Global Moderator
Re: Free App To Recovber Files From Sd Cards
« Reply #1 on: October 20, 2018, 01:44:17 am »
If it's just photos, videos and other media QPhotoRec is probably your best option.
Runtime Software also made a free version of their GetDataBack software called GetDataBack Simple 1.02, but I'm not sure if they offer it anymore. You might be able to find a link to the previous version.
The following users thanked this post: nvidia
« Reply #2 on: October 20, 2018, 02:11:46 am »
thanks I will give PhotoRec 7.1 a try will it work on formatted sd card I know  2 or 3 where formatted because I wanted to use in another camera but never did
« Last Edit: October 20, 2018, 02:15:48 am by nvidia »
Offline Halcyon
  • Global Moderator
« Reply #3 on: October 20, 2018, 04:48:44 am »
Formatting almost never actually overwrites data on a storage device, it just recreates the partition table and marks the rest of the disk empty for overwriting leaving most/all of the data intact.
Offline BradC
« Reply #4 on: October 20, 2018, 07:01:04 am »
True, but it wipes the FAT so any files that were fragmented are pretty hard to recover as there is nothing left to link the fragments. There are a few apps good at recovering contiguous files though.
Offline magic
« Reply #5 on: April 07, 2020, 07:17:49 pm »
Time doesn't matter unless you write new data to the card. If new data end up written to the exact same location as a deleted file then you won't get the deleted file back, except for cases of extreme luck and extreme hardware hacking.
This is true for a "quick" format. If you format using a camera, many of them will be happy to do a "low level" format which issues trim commands to the card and makes data almost unrecoverable.
« Last Edit: April 07, 2020, 07:19:52 pm by magic »
