OK, to be pedantic, R134a isn't really "Freon".
Many years ago, a friend of mine gave me a roughly 3 inch piece of 1/8" copper tubing filled with a little R134a and sealed at both ends. It was intended to demonstrate how refrigerants carry heat. After lying around for so many years, I decided to try to find a use for it. It so turns out that the cheap (and not so cheap) plastic cases for the Raspberry Pi are terrible thermal wise. I carefully bent that piece of tubing into a loop and epoxied it to an old NB heatsink on one end and a filed down penny (heatspreader) on the other end. I cut a hole in the case for the heatsink so it can mount on top.
It's way overkill, but it sure looks cool. And it does indeed keep the CPU very cool.
