No bdunham7. That is not what I am trying to say. "2N3055" has understood me better what I am trying to say.
What I am saying is that it is possible to take copies of a 100 Mhz signal (to give an example) and display them at a much lower frequency, so that they can be viewed on an inexpensive low bandwidth oscilloscope.
If you take a single sample per period and repeat the same thing for 10,000 periods, when you reconstitute the signal, it will be an exact copy of the original signal, but its frequency will be 10,000 times lower. By doing that it is possible to observe a 100 Mhz signal as if it were a 10 Khz signal, something that any cheap oscilloscope can do.
And it is not difficult to achieve. The only thing necessary is to have elements that work properly in the UHF band. I did it with BFY90, MPF102, BF960 transistors and and some TTL-Shotky flip-flops. And the resistors should be non-helical so they have almost no inductances.
And I could see UHF signals on a simple Telequipment D61 oscilloscope.
And I think that's what GlennSprigg is looking for , only that when he made his first query he expressed himself badly because he mentioned a "prescaler" which is used only to measure frequencies and not to observe waveforms, although if we go by the concept of the term "prescaler", what we are doing on the oscilloscope is conceptually something similar: moving to the low frequency domain something we can't observe or measure in the high frequency domain.
