Author Topic: How did this even get through QA? (Chinese boost converter)  (Read 1535 times)
Offline bd139Topic starter
« on: December 02, 2017, 11:03:33 am »
Decided to order a bunch of stuff from China just to see if it will indeed handle the outlandlish claims that are made on the auction bodies.
Item number one arrived today, which is a little boost converter. Supposedly if I chuck in 5V @ 1A, it'll kick out 12V @ 370mA out switching around 1MHz. That's a respectable estimate compared to some. I've seen things like this advertising 5A out  :palm:
Well it would if the output filter was actually attached at one end:
Only one side is actually a good solder joint. The other end, not pictured is floating.  :palm:
« Last Edit: December 02, 2017, 11:05:16 am by bd139 »
Offline Kilo Tango
Re: How did this even get through QA? (Chinese boost converter)
« Reply #1 on: December 02, 2017, 12:41:38 pm »
and that cap next to the connector has been knocked over physically breaking both joints
Maybe chinese don't actually test stuff, they just build it and ship it.
Ken
« Reply #2 on: December 02, 2017, 12:43:33 pm »
Nope, thats just a "floating" output.  :-DD
The following users thanked this post: IRFP460
Offline retrolefty
« Reply #3 on: December 02, 2017, 12:50:30 pm »
Well how does it work after you repaired it?
« Reply #4 on: December 02, 2017, 12:59:47 pm »
Repaired (badly) and tested. It's quite decent. Looks like it passed because the cap was on the input side of things. It's a 10uF MLCC for ref. I measured it out of circuit.
I think it had lifted before the solder had returned to solid and it was just tombstoned there. Joint wasn't actually broken
I can pull 6W out of it (500mA at 12V) for 8W in whilst blasting the shit out of it with a hairdryer. Still going strong even if the breadboard is melting (I used a crap one just for this test).
Tentacle monster testing it:
Output:
Not bad for under £1.
« Last Edit: December 02, 2017, 01:02:22 pm by bd139 »
