If you ever saw any 'inside pics' of the concord, 1 rack type panel was almost flush with a vertical divider on take-off, and there was a 100mm gap in flight at max fuselage temp, so heat of the airframe going at high mach speeds, even in the upper atmosphere will need a lot of work.
