Was out the back of my exe's house for a smoke at Christmas and looked up above her back door to see two large, probably 25mm insulated tails running across her roof eves.
I followed said tails and they were clipped all the way along both semi-detached bungalows and then tension wired across to the next pair.
At her door there were two of those weather sealed taps that drive into the tails. It was too hard to see if both tails went into the consumer unit, or only one.
Is this likely to be a small ring around the bungalow "close" to save putting it underground, or maybe retro fit? That would make it Line/Live only and make the houses self earth referencing TTS? Either that or it's L+N and the houses are just on a multi house spur.
What struck me as really odd though and why it stuck with me. These are at around 7ft off the ground. You can literally reach up and tug on them just above head height. They are really, really trusting those tap things are sealed from rain, damp and accidental contact with people. I would not want to be on the end of that shock.
